how to install fog lights to 99 SR5 ..next postmaan 03-08-2004, 07:54 PM friends my next post will be how to add fog lights (amber color) to your SR5 99 for less than 30 dollars cost and 90 minutes labour ..do it yourself job ...would be just like the original ones .dealer was asking for 600 dollars just for the lights and i did it for 30 dollars cost ? big time saving huh ? Brian R. 03-09-2004, 03:53 PM Mine cost me $400 installed. maan 03-09-2004, 08:22 PM Mine cost me $400 installed. Mr. brain i missed to tell 600 dollars candian which is exactlly 400 US $ coet me 30 candian and one hr and half labour Brian R. 03-09-2004, 10:08 PM Sounds right :) homebasix 05-16-2004, 08:02 PM friends my next post will be how to add fog lights (amber color) to your SR5 99 for less than 30 dollars cost and 90 minutes labour ..do it yourself job ...would be just like the original ones .dealer was asking for 600 dollars just for the lights and i did it for 30 dollars cost ? big time saving huh ? Dude, I have bought some after market foglights. When I get under the front end of my 99 4runner, I see wiring connections that are unused taped to the one's running to the main light cluster. Are these for the fog lights? There is a red translicent rocker switch on my dash (lower left) that I assume is there for fog lights? Do I simply tap into this wire or do I need to wire the whole thing? Do tell!! Cheers XPY 09-06-2004, 07:14 PM Dude, I have bought some after market foglights. When I get under the front end of my 99 4runner, I see wiring connections that are unused taped to the one's running to the main light cluster. Are these for the fog lights? There is a red translicent rocker switch on my dash (lower left) that I assume is there for fog lights? Do I simply tap into this wire or do I need to wire the whole thing? Do tell!! Cheers Originally Posted by maan friends my next post will be how to add fog lights (amber color) to your SR5 99 for less than 30 dollars cost and 90 minutes labour ..do it yourself job ...would be just like the original ones .dealer was asking for 600 dollars just for the lights and i did it for 30 dollars cost ? big time saving huh ? I would like to know the answer to both these posts? Brian R. 09-06-2004, 07:31 PM homebasix is correct in assuming they are for the fog lights. You have to insert a separate switch on the dash for them. The originals controls were on the stalk. XPY 09-06-2004, 08:02 PM My truck also has the wirring connections in place and taped to the main light cluster wires. I have no switch in my dash. If I could find a Stalk control it would just be a matter of changing it. Installing the fuse under the hood, and pluging in the fog lights. Or would their be more to it? I guess my question is since the wirring harness seems to be in place is it just a matter of getting Fog lights, a fuse, and a sitch?? Brian R. 09-06-2004, 08:57 PM May not need the fuse. The wires may be fused already. XPY 09-07-2004, 10:00 PM Actually the owners manual (under fuses) shows the location of the fog light fuse as being under the hood. I checked. It's there & just needs a fuse installed. Someone mentioned a relay not sure if it requires one? Automotive Network, Inc., Copyright ©2012
