misfire cylinder-4
I am working on a 1999 Plymouth Neon DOHC automatic with 69k. The engine has a very rough idle. Code says misfire cylinder 4. I have replaced the spark plugs twice. First with platinums, then with OEM Champions. I have also replaced the plug wires, coil pack, and one fuel injector. I have tried fuel injector cleaners and different brands of premium gas. Disconnecting the battery seems to clear the problem for 1-3 days. The oil is clean with no signs of coolant and the engine runs fine at anything other than idle. The local dealer doesn't know what is wrong, but says it may be a bad valve spring or camshaft. I don't really buy that explanation given the problem goes away (temporarily) after disconnecting the battery. If the cam is bad, it would run bad all the time. Plus, I would tend to think a bad spring would make the engine run worse with higher rpms. This problem exists only at idle. Any thoughts?
