car trouble, engine noisemanji240 03-07-2004, 10:40 PM my 1991 240sx (137,000miles) seems to have a slight noise from the timing chain area in the front of the engine. we pulled the valve cover and did not see anything that stood out. i would appreciate any help with it if anyone knows. thank you KenOhki2112 03-07-2004, 11:01 PM If the noise only happens for the first 15 seconds or so of starting up, this is normal for the 240, and should be comming from the timing chain area, and according to nissan is not a deterimental to the car. If it is persistant, then you have a problem. nissanfanatic 03-07-2004, 11:20 PM remove the upper chain guard. www.240sx.org manji240 03-08-2004, 09:19 PM remove the upper chain guard. www.240sx.org is this a problem, or is it common for a 240 to have that happen at 137,000 miles.( what does that mean, does my chain have slack in it, should i replace it?) KenOhki2112 03-08-2004, 09:35 PM is this a problem, or is it common for a 240 to have that happen at 137,000 miles.( what does that mean, does my chain have slack in it, should i replace it?) I don't know of a single KA 240sx that hasn't had this problem. If the noise doesn't bother you much just leave it alone, it won't really hurt anything. If you want to stop the noise check out 240sx.org. manji240 03-10-2004, 07:00 PM its a dual overhead cam!! nissanfanatic 03-10-2004, 10:03 PM It is almost inevitable unless you idle everywhere. the chain does stretch some, but more than likely the tensioners are worn out. zdude 03-11-2004, 09:02 PM ummm...manji240, where does he say its sohc?? if your refering to "singe ka 240 sx" he means he hasnt seen a ka without a problem. has nothing to do with dohc or sohc vsiev 03-11-2004, 09:16 PM yea he got issues about people thinking a 91 is a sohc...which it is not but still lol Automotive Network, Inc., Copyright ©2012
