waring lights
dugfish
03-07-2004, 02:31 PM
2000 olds alero anti lock waring light comes on plus traction light comes on plus service engine light comes on same time car runs perfect can i disconnect something to stop this problem
JTrujillo86
03-07-2004, 04:00 PM
I'll bet $100 your alternator is gonna go within a week or so. About a week before my alternator took a dump in my Malibu, my dashboard lit up like a Christmas tree, with no appareynt problems. Are all of the lights on steady all the time or do they come and go? If they come and go then it sounds like the alternator. If they are all always on, I would take your car to Autozone and they can check using a scan tool to see what codes, if any, are being thrown.
Hope this helps -
JeReMy
dugfish
03-07-2004, 08:30 PM
Hope this helps -
JeReMy
been having trouble about 3 mo. comes and goes had it scaned would not showing any abs codes said wire problems in wheel sensors have to check all wheels alternator ok...hope he can find problem or disable it
DamienZ28
03-09-2004, 03:29 PM
Sounds like the sensor in your wheel bearing might be going bad or like jt siad the alternator might be dropping voltage or spiking causing the x-mas tree light dance
JTrujillo86
03-09-2004, 04:46 PM
I'm leaning more towards the alternator because if were just a wheel speed sensor or other sensors in the area, your ABS light would only come on, only come on, not all of the ones you mentioned.
Jeremy
dugfish
03-24-2004, 06:44 AM
going on over 3 months now waring lights still on
car runs perfect no problem some times they come on when iam driving when i stop turn car off it resets when i start back up its stays off till it acts up again if alternator going bad its takeing a long time to quit.
JTrujillo86
03-24-2004, 01:31 PM
Today I had a funny issue with the 'BRAKE' warning light. I parked the car and pulled the e-brake up. The light came on like normal and I shut the car off. All of the lights on the dash at this point shut off. I went into the doctors office for about 30min and when I came out to start my car, I noticed the brake warning light was light WITHOUT the car on, running, and even without the key in the ignition. It was really odd seeing everything shut off when I turned the ignition off. Anyone know what might be causing this? Maybe and electrical issue?
Jeremy
wpbharry
03-24-2004, 04:43 PM
Poor Jeremy, out of the frying pan and right smack dab into the fire.
And this dumb ass might just be buying a new Maxx after another horrific, and similar, experience with a 97/98 Malibu. Seems the Alero is worse.
Certainly not to discount AF, but SOME of you need to join us in c&g, which is all new come next Monday, the 29th. Fun for GM fans (and not fans), far and wide. You might just be shocked who you'll meet....
dugfish
03-31-2004, 06:41 AM
for sale $5000
