need help engine losing power.......
amadeus
03-07-2004, 02:10 PM
ok i'm not a mechanic and really have no experience working on cars so i'd like to explain what i've noticed and get some insight from you guys as to what might possibly be the problem.....
i have a '91 MR2 with 150,000 miles on it. i've noticed that when i'm driving once i get into 5th gear (it might also happen late in 4th, but deffinately in 5th) i lose alot of power and start dropping speed. i usually can only get around 50mph with out reving the engine to around 4000+ rpms. any ideas on what could be causing the problem???
thanx to all in advance!
Mr2dIzzy
03-07-2004, 02:30 PM
How are u losing it ? Is it Reving out or bogging out. Theres alot is it stick or auto? your clutch could be going. Is it turbo? theres so much you need to give more info
amadeus
03-07-2004, 02:41 PM
non-turbo. stickshift. was told recently my clutch was a lil loose. as for losing power it seems when i shift from 4th to 5th gear the power and speed just drops out.
define reving out and bogging out please?
Mr2dIzzy
03-07-2004, 02:51 PM
The clutch could be your main problem along with the flywheel. OK when your in 5th besides losing speed what does your motor sound like? is it still gaining in rpms and losing speed or is it just dying altogether
amadeus
03-07-2004, 03:00 PM
sounds normal till i give it more gas which of course increases the rpms which (eventually) increases my speed.
Mr2dIzzy
03-07-2004, 06:31 PM
Yea it sounds like your clutch and if you have pushed it so much your flywheel needs to be replace too
amadeus
03-07-2004, 07:15 PM
how much $$$ would that run me??
JekylandHyde
03-08-2004, 09:51 AM
Sounds like a clutch to me.
rollhard
03-08-2004, 12:15 PM
will cost you around $350
bigpun
03-08-2004, 12:23 PM
your going to slow for fifth gear shitheel
rollhard
03-08-2004, 12:40 PM
its wierd though because if you are accelerating fine for the first 4 gears thats funny. usually when the clutch goes getting off the line is difficult. in the higher gears as long as you dont mash it, it usually allows you to gain a lil speed since the car is already rolling. if you try to accelerate hard in 1st does it slip? and can you smell the clutch burning?
amadeus
03-08-2004, 01:45 PM
i'm going 50+ before i enter 5th gear.
yea there is a slight smell but i'm not sure when it starts.
how difficult is it to work on this (if it is the clutch) myself??
rollhard
03-08-2004, 02:25 PM
hmm, well in all honesty, if you have to ask if its hard or not, then i would not recommend you changing the clutch yourself. when we did my clutch the motor had to be dropped and the tranny taken out. it took FOREVER. i think like 10 hours to swap clutches. depending on where you live you can get it done by a reputable shop for a pretty decent price. There are some good shops in cali that do it for a fair amount.
amadeus
03-08-2004, 03:21 PM
i'm up in washigton state. i'm in the military so i can go to the auto shop on base and get some help doing it from certified professionals but i'd still be the one doing it.
amadeus
03-09-2004, 10:00 AM
OK i paid closer attention to how it drove this morning. it is kinda slow off the line in 1st. once i get going i'm generally ok but at moments no matter what gear i'm in it seems to lose power (i'n 5th especially dropping from 60mph to around 35mph) and then after a few moments building speed back up. i've stopped trying to push the rpms to keep the speed up and have kept it around 3000rpms. i think i'm gonna not drive it again till i've gotten it fixed.
still think it's the clutch???
JekylandHyde
03-09-2004, 10:10 AM
If your RPMS rise and your mph does not, it is your clutch.
If your clutch completely goes, you will not be baleot engage any gear.
rollhard
03-09-2004, 10:59 AM
.......to lose power...........
..........still think it's the clutch???
I think its your clutch and NO, you are not losing power. there is a difference. your car is just not going cause the clutch. if you were losing power, your rpms would not go up either.
amadeus
03-09-2004, 11:04 AM
ok thanx all..... on base we have an auto shop with pros that will help me figure out the problem and help fix it. tomarrow when they're open i'll take it in to get it verified it is the clutch. then this weekend i guess i'll spend a day working on it.
thanx again!!!
mr2inprogress
03-10-2004, 04:58 PM
Mine is a 93 N/A it did the same thing its the clutch I hardly noticed any slipping(RPMS go up car doesn't accelerate) until 5th gear if u've been driving it like that you'll probably need the throw out bearing and the flywheel and if its got 150K u should replace them anyways mine had 130K when I did it and they were shot to shit
