97 Taurus Problemsjoeinohio 03-06-2004, 05:43 PM My 97 Taurus is having problems: 1. My wipers will not turn off after I turn them on unless I turn the car off. They only work in low and high as well (no intermittent) 2. My horn quit working 3. My cruise control no longer works. I was thinking that I could find something in common with all three and replace it and solve the problem if I'm lucky. Any ideas would be greatly appreciated. (I was thinking it was a relay of some sort) naturalhoosier 03-06-2004, 07:21 PM Have you checked for any blown fuses? joeinohio 03-07-2004, 11:10 AM I've checked my fuses but no luck. It all started when my roommate went to start my car for me while I was out of town and set off my alarm(forgot to use the keyless entry). He called and said the horn had been going off for a whille and then it all of a sudden quit. I got back in town, it no longer worked neither did the cruise control. Any ideas? vicv 03-20-2004, 09:16 PM Did you check the maxi fuses in the engine compartment too? yungtek 02-07-2010, 05:11 PM Someone disconnected the wiring harness under the dash to kill the horn, or... if you live in a damp environment the contacts are corroded on either the harness or the slip rings in the coulomb. Automotive Network, Inc., Copyright ©2012
