replaced alternator & battery/battery still dying
krazidame7
03-05-2004, 10:15 PM
PLEASE help before i pull out all of my hair...i just had a load of work done to my 92 3.4L euro lumina...oil seal,head gasket set replaced, timing belt,spark plugs, s plug wires, timing blt tensioner, drive blt tensioner, valve seals, battery & alternator!!!!!!!! paid over 2000$, what the heck could it be?? if the alternator & battery are replaced, what else? it was staying charged for 3 days after the alt was installed. OH! and there is a miss in the engine & i have no idea what is causing it...and neither does my idiot mechanic! when I hit about 50 mph, it shakes! PLEASE HELP!
burly
03-05-2004, 11:45 PM
Is the battery going dead during driving, or is it dying while it's parked ? Do you know what voltage the charging system is supplying and how many amp alternator is installed? Also, is there any additional electrical equipment in the vehicle (e.g. amplifier) ?
If its dying while its parked, then there could be something in the car that is draining the battery when it is off. If the battery is dying during driving, then there are is a faulty part or connection in the charging system.
Nexagen
03-06-2004, 06:12 AM
My suggestion is this:
1)Buy Diehard Battery - These batteries are some of the best car batteries you can buy because they will not fail you at freezing temperatures and last MUCH longer than your average battery.
2)Replace your sparkplugs - Could be that one of them is bad and may not be giving you a good spark.
3)Replace your Spark Plug Wires - One of your wires may be fried or something else could be wrong.
4)Replace your battery wires - Could be that there is a segment in your cables that is cut off/disconnected and not giving you power.
5)Check your fuses in your fuse box to see if you have a blown fuse. If that is the case replace it or take it to a good mechanic to have the fuses checked out.
If the above does'nt work consult with some mechanics or auto specific professionals.
Nexagen
03-06-2004, 06:17 AM
My car had a little bit of water but I took it to a Jiffy Lube and made them flush the engine of all liquids (Oil, Engine Fluids, Contaminants, etc.). Then I put some Royal Purple Synthethic Motor Oil and it ran like a champ.
When it sucked in water it would studder and feel like it wanted to stop at around 2,000 RPM's to 3,000 RPM's and it would usually be when I accelerate.
So basically what I think you should do above all else is this:
1)Flush the engine by taking it to an Oil Change Shop like Jiffy Lube (ONLY IF YOU THINK WATER GOT INSIDE YOUR ENGINE)
2)Change the oil (Royal Purple is top grade to all motor oils)
