My mom had a 98 rav and the power windows quit working. Also the power locks quit too. I have checked all the fuses and they are good. I am thinking it is the master switch on the drivers side bad but i am wanting another opinion. Thanks
are any of the windows working or any of the power locks working from any of the doors, strange for all of them to quit at once, simple, make sure window lock button is not on, common problem, check connector on bottom of master switch, if loose , it is possible master , but not likely, let me know if all inop or just one
They all dont work, power locks are inop also. All fuses are good. I know all the windows run through the master switch, the thing is $356.00 At the dealer!!! I just want to be sure that is it.
I am having a similar problem but the drivers side window is functioning. The power locks works to but all the passenger windows don't work. They don't work no matter which controler I use. If I use the main driver's side they don't work and if I use the contoller on the same door as the window (ex: front passenger door/front passenger window also does not work). Any ideas - my passenger side window is down and its supposed to rain and snow tonight.
