Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Tercel
Old 03-01-2004, 01:40 AM   #1
TcelDuder
TcelDuder Normal reputation
Angry Help Me swap my engine.
Well here is the thing.. I'm getting a 5E-FE engine, However, the problem is that I NEVER DID AN ENGINE SWAP BEFORE. I'm only good at body work, but I've learned that with a 5E-FE engine, It can be put in Direct bolt on and that it can be done in my garage or my back yard. If you guys have this engine and you did it yourself. Help me out guys.. Im a little and because i dont know what to do. I have some of my family that will come and help because they did it before but their more experienced with hondas. Tell me How to swap the engine and what i will need. LIke a list and step by step how to do thing. OR give me a website that tells me how to swap a 5E-FE engine into a tercel... THANKS GUYS
TcelDuder is offline   Reply With Quote
Old 03-16-2004, 12:53 AM   #2
turcelbo
turcelbo Normal reputation
Send a message via AIM to turcelbo
Re: Help Me swap my engine.
Deng mayn I'm in the same boat as you I'm swapping a 5E-FE into a 1991 'Cel so I can get rid of my 3E-E. All I know is that you need a new ECU, wiring harness and a new timing belt. You should check to see if the trans will fit also.
turcelbo is offline   Reply With Quote
Old 03-17-2004, 06:17 PM   #3
Tercel GTS
Tercel GTS
Send a message via Yahoo to Tercel GTS
The tranny fits
click to chat at StonerScript
Tercel GTS is offline   Reply With Quote
Old 05-14-2004, 10:20 AM   #4
Schweinhund
Schweinhund
You need a service manual. The torque specs are invaluable, and it will outline everything step by step. If the engine is a direct bolt-in, then no problem. I have swapped maybe a dozen engines in Hondas and Acuras, and my girl's Tercel is going to need one soon. I looked at it and it should be a breeze, so don't be too intimidated. It's also well worth the money to change the clutch, timing belt, h2o pump and drivebelts now, and resurface the flywheel. These are easy to do with the engine out, although the Tercel is a breeze to work on. My first swap took me over a week (I kept getting stuck, and it was a very tight fitting engine) but now I do it in a day or two, start to finish, so get a friend who has done it before to help you in the garage.
Genau mein Ding.
Schweinhund is offline   Reply With Quote
Bookmarks
Google
Web AF
