1996 starting problem, check engine, EGRjeeaton 02-29-2004, 03:03 PM Our car has a problem where the check engine soon light is on at all times. In warmer weather, the car will have a very hard time starting sometimes. Once this happens, and it does finally start, it will idle rough for a minute until you get going, and then it's fine. We had Autozone look at the check engine code, and it said it was getting bad EGR readings. I replaced the EGR valve itself, but the problem still occurs. Does anyone know what this is? Thank you hopeless4life 02-29-2004, 05:19 PM check for vaccuum at your egr valve. jeeaton 03-01-2004, 01:31 PM Thank you. I'll give that a try. Automotive Network, Inc., Copyright ©2012
