1995 Jimmy with S-L-O-W signal lightstvshooter 02-29-2004, 12:53 PM For some reason the blinker lights on my '95 Jimmy blink very slowly, although the battery seems to be fine. Is this a relay issue? amac209 03-02-2004, 02:40 AM the flasher unit might be shot. do the hazards work?? do all the brake lights work?? try smacking the top of the steering column gm has a problem with the multifunction switch on these things. tvshooter 03-02-2004, 03:00 PM Hazards and brake lights work fine. Where is the flasher unit located? amac209 03-02-2004, 04:06 PM under the dash somewhere turn on the signal that works and follow the clicking sound. riptreeper 03-09-2004, 01:01 PM I have the same problem on my 96 what could it be tvshooter 03-10-2004, 01:07 AM If you find out, please post it on here, and I'll do the same! riptreeper 03-10-2004, 11:12 AM sounds good to me stevek7 05-01-2004, 11:46 AM same problem here. Had to take to a mechanic to fix. not flasher or relay....... tvshooter 05-05-2004, 11:11 AM So what was the problem??? Automotive Network, Inc., Copyright ©2012
