2jz Engine In A 3000gt Vr-4 ???
Kabs
01-03-2002, 10:03 PM
Is it possible to fit the 2jz engine into the 3000gt??? If so would it be expensive :D
ZYAL8ER
01-14-2002, 11:23 AM
Why The Hell ??!! The 3000GT engine can do what ever and as much as any Supra or 300Z engine can do the only thing i would switch about the vr4s engine for the supras would be the engine harmonics the supra sounds so NICEEEEZZ.:o
designerarts
01-17-2002, 01:32 AM
If you want a nice upgrade and your engine is blown I would go for the 345 hp Corvette Engine and the 6 speed manual trany. It will cost you the same but if you look further, a stock VR4 has 320 turbo aspired HP and a stock 98' corvette has 345 naturally aspired hp try droping a 20G twin turbo system for another 5 grand and your set with a 600 HP monster.
UncleMeat777
02-04-2002, 01:48 AM
345? Eh... if you're gonna do a V8 conversion, there is a place online (you'd have to do a search) that will sell you a 700+ HP LS1 engine. Now, that'd be plenty of muscle. No turbo required.
However, I was wondering about dropping in that supra engine myself, the location of the turbos would be the #1 advantage for me.
Blackbird01
02-05-2002, 07:26 PM
A 3000GT can do anything a Supra engine can do?
Since when?
Never realized a 3000GT could handle 1000hp on stock internals.
I've heard the 3KGT fuel system blows...?
Spence3000gt
05-22-2002, 12:31 AM
i have a base 97 3000gt
i was wondering if there what kind of swap i should do to make it much faster.
and would i have to change the fact that it is fwd
Grendel
05-22-2002, 01:36 AM
I never knew 3000gts were fwd... *shrugs*
-Grendel
Moppie
05-22-2002, 02:06 AM
Theres one other little problem, Just where are you going to put it?
Go measure up the length and height of a 2jz and then see how well it will fit in the frount of a GTO. :D
And remember you have to fit the 4wd transaxle behind it.
Spence3000gt
05-22-2002, 06:30 PM
Is it possible to put a vr4 engine into a base. Leave the same transmission. and just buy turbos and intercooler, and ecu
lloyd_nickens
05-23-2002, 11:16 AM
I thought the engine was the same just turbocharged??
ahsiao
05-23-2002, 01:29 PM
then y do u buy a base in the 1st place???
anyway... its possible to put a vr4 engine into base... but i don't think u can find one.... its too rare....
UncleMeat777
05-24-2002, 01:44 AM
Rare? You can buy a VR4 short block from ANY mitsu dealer. Cost you close to $3k. As for putting a VR4 engine into a base, no. 1) I doubt the transmissions would line up. 2) you'd need a new ECU. 3) the cost of the project would be so high, it'd be cheaper to sell the base and get a VR4. FAR CHEAPER.
You'd never get the AWD going. Only way it'd work is to cut/weld a new mount for the supra tranny... make the VR4 RWD, guess it'd be a VR2...
Anyways, I think this is a dumb idea anyways. Just like that guy that put a skyline engine in a Supra. Just doing stuff because you can.
YogsVR4
05-24-2002, 11:54 AM
I know of that being done on two different cars. I would have been cheaper to just buy a VR4, but if your up for the work, it can be done.
NA Beef
07-07-2002, 11:14 PM
Just found this thread. I want to go ahead with a V8 conversion, but all I can find is a motor mount conversion kit. Any ideas on where to find a complete kit, or someone who has the done the swap? I've got about $6000 set aside for it. Should be enough?
JGarcon
10-05-2002, 05:36 PM
:monkeypis Cannot put a Corvette engine in a 3000 GT because the corvette engine sits front to rear and the 3000Gt (GTO) sits sideways. Do your homework first and stop talking bull before posting.
:silly: Now if you want to disturb the structural density of the car then yes it can be done. but make sure to put a role bar in it.
ANYWAYS Has everyone seen the new . Subaru Impreza WRX . :eek:
For a 4 cylider TURBO! It kicks out 227 HP at 6,000 rpms (redline 7,000)
It is a ALL WHeel drive and the pistons are positioned to go sideways instead of up and down. curb weight 3,085
It is the same car they use for the rally wow. I am a V6 lover but that 4 cylinder kicks but. and the best part is that the engine sits fron to back with the intercooler on the hood.
NA Beef
10-05-2002, 06:21 PM
What kind of Moron are you? I asked for info on making the swap. I've swapped a dozen engines, and some had to be modded for transverse engine replacements. No bull here. If you aren't part of the solution, you're part of the problem. So. shut your pie hole.
UncleMeat777
10-06-2002, 12:40 PM
"Cannot put a Corvette engine in a 3000 GT because the corvette engine sits front to rear and the 3000Gt (GTO) sits sideways. Do your homework first and stop talking bull before posting."
How is that different from a Supra motor? New engine mounts and cut/weld a spot for the transmission. Any idiot with a few bucks can do it. Go home.
mehrshadvr4
02-22-2006, 09:51 AM
Since when?
i never realized to see some one that think you can make 1000hp on supra engine with stock internals:rofl: .you wont even be able to make 1000 hp on stock putom end.3000gts engine can make about 900hp with modes.that's same as supra engine or maybe even more.
SHO411
02-22-2006, 10:35 AM
Why spend $6000 on a V8, then mod this and that. not including ECU, and tons of other stuff, and by the time it's done, you'll need more than 6K unless you are doing 80 of the labor.
Take the 6K and rebuild the VR4 block, some turbo upgrades, and you'll have your 500hp.
97SLGT
02-22-2006, 02:47 PM
I'm done with all the laughing:grinyes: . Where the hell is Hotshot?
mehrshadvr4
02-22-2006, 07:02 PM
if he wants to put only 500hp he can make that power with less tha $2000.:screwy:
Morphius289
02-22-2006, 07:07 PM
Hmm. If you're willing to waste the money, I don't see why not. If you throw enough money at it, you'll probably be able to get most anything to fit.
Ralliart 3000gt
02-22-2006, 08:12 PM
eh, just stick with the 3000gt VR-4 engine and mode that. who the F@#$ wants a hybrid....... those cars are a freak of nature........Frankenstein.........ITS ALIVEEEEEEEEE!!!!!!
no but honestly you don't want to mess with the AWD set up and the 3kgt is capable of more than enough hp........
youngvr4
02-22-2006, 08:16 PM
this thread is so old, i want even here when this was first posted
leave the dead dead
