Re: Modifications?!?
alright for starters, i hope you didn't just bolt on a turbo. for one thing the pistons have too high of a compression, it could be done but you would have to run minimal boost. secondly i hope you have a good fuel management system(hi-flow fuel pump, fuel pressure regulator, and bigger injectors) after all that, you would definitely cant use headers with a turbo, so a good exhaust manifold, full exhaust, and a bigger TB and MAF sensor(not sure if neons use this). with that combo u should have a pretty quick car.
