32's on stock rims?
jasonja
02-26-2004, 08:59 PM
Does anyone know if you can run 32 inch tires on the stock 15 inch tacoma alloy rims with no rubbing? I am looking to get new BFG MT's in 32x11.50x15... Any help on this question will be much appreciated.
'03DC3.4TRD4X4
03-01-2004, 04:35 PM
they will rub off road for sure.
redtoy92
03-04-2004, 02:35 AM
he is more then right! you can run those tires on the stock wheels with no problem but with out a lift you will rub on full turns and off road. red
Lonestar39
05-06-2004, 12:56 PM
What is the minimum lift needed to handle 32's on the stock 15 X 7's (2000 4x4 ext cab)? Is there any hammering, grinding on something that would alleviate some of the rub without compromising safety or escalate wear? Looking for a cheap way to get 32's on mine with very minimul rub. I do very little off-roading that is hard on the vehicle.
Thanks!
nickbo
05-12-2004, 02:51 PM
you will need at least a 2" lift, 2.5 just to be safe. you could run 33's with a 3" lift too
dfskinner
05-17-2004, 01:54 PM
The stock rims are 15x7, can you put a 12.5" wide tire on a stock rim?
tacolover
06-15-2004, 05:36 AM
i have a '02 4wd taco with a Fabtech 3" lift on 15x8 rims with 32x11.50 bfg mt's and they rub on a full turn. It can be fixed with minor trimming. all you need is a razorblade.
jonb_24
06-15-2004, 02:01 PM
tacolover,
do you like the fabtech lift. how does it handle. noticed any excessive wear. where did you get it and how much.
thanks
jonb_24@hotmail.com
