Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Corsica
Old 02-24-2004, 01:30 PM   #1
scootwag
scootwag Normal reputation
PCV valve
Can anybody tell me where the PCV valve is located on my 1989 ,2.0L Corsica ?
scootwag is offline   Reply With Quote
Old 04-05-2004, 10:30 PM   #2
89 corsica
89 corsica Normal reputation
Re: PCV valve
i not sure about the 2.0l but on my 2.8 its above the spark plugs on the back of the engine in the middle
89 corsica is offline   Reply With Quote
Old 04-05-2004, 11:31 PM   #3
406Elcamino
406Elcamino Normal reputation
Re: PCV valve
If you have the ribbed aluminum valve cover it's under the fitting that screws into the valve cover. Right where the hose is.
406Elcamino is offline   Reply With Quote
Old 04-06-2004, 09:33 AM   #4
scootwag
Re: PCV valve
Thanks for info, will look for it there. Does the valve cover have to come off do you know?
Old 04-06-2004, 11:04 PM   #5
406Elcamino
Re: PCV valve
No, it doesnt have to come off. Just unscrew the plastic fitting.
Old 04-07-2004, 02:27 PM   #6
scootwag
Re: PCV valve
Thanks
Old 05-13-2004, 07:08 PM   #7
Wicorsica
Wicorsica Normal reputation
Re: PCV valve
does anyone know where the pcv valve is on the 3.1 v6 corsica?
Wicorsica is offline   Reply With Quote
Old 05-15-2004, 09:22 PM   #8
satanstoystore
satanstoystore Normal reputation
Send a message via Yahoo to satanstoystore
1993 3.1 v6 pcv valve
to locate for that, look under your MAP sensor and towards the driver side. It's inserted into a manifold and has a very large hose coming out of it pointed towards the front of the car.
Now, after you find it respond to this thread and tell me how to get the thing out to replace it!
satanstoystore is offline   Reply With Quote
Old 05-16-2004, 12:45 AM   #9
406Elcamino
Re: PCV valve
If I remember right that motor has the big flat intake manifold. Be really careful. The hose on the valve is molded and is very easy to crack after its been around a few years. If it breaks you might as well plan on pulling the upper intake off and calling the dealer for the hose.
Old 05-16-2004, 12:01 PM   #10
quaddriver
quaddriver Normal reputation
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
the pcv on the 660v6 is a challenge to get at. easiest way is to unbolt the throttle body, unbolt the egr tube, then unbolt the upper plenum and lift enuf to get at it.
you can also try just removing the rear valve cover and dropping it low but you need patience and a swivel to get the w upper 8mm bolts off.
quaddriver is offline   Reply With Quote
Old 05-31-2004, 12:17 PM   #11
Wicorsica
Re: 1993 3.1 v6 pcv valve
i used 2 long needel nose plyers held the hose with one and just pulled on the pcv valve... it worked well
Old 01-04-2006, 04:10 AM   #12
ZerO281eCHo
ZerO281eCHo's Avatar
ZerO281eCHo Normal reputation
Send a message via AIM to ZerO281eCHo
Re: PCV valve
what does a pcv valve do?
ZerO281eCHo is offline   Reply With Quote
Old 01-04-2006, 05:02 AM   #13
corning_d3
corning_d3 Normal reputation
Send a message via Yahoo to corning_d3
Re: Re: PCV valve
The PCV valve is just one part of the PCV(Positive Crankcase Ventilation) system. The PCV system removes all the volatile gases n such that sneak past the rings into the block, and burns them in the engine. The PCV valve is only a one-way check valve.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
corning_d3 is offline   Reply With Quote
Old 01-04-2006, 05:27 AM   #14
ZerO281eCHo
Re: PCV valve
so is it like another egr valve?
Old 01-04-2006, 12:53 PM   #15
Ed_Strong
Ed_Strong's Avatar
Ed_Strong Normal reputation
Re: Re: PCV valve
Not quite...
EGR (Exhaust Gas Recirculation) takes burned fuel gases from the exhaust system back into the intake and recicles them to lower CO2 emissions and add more volume to the air/fuel mixture to lower fuel comsuption.
PCV (Positive Crankcase Ventilation) takes the fumes and contaminants from the burned motor oil and burns them before letting them escape into the outside.
So, one takes care of the exhaust gases (EGR) and the other takes care of the burned motor oil (PCV) they both help keep the environment.
Ed_Strong is offline   Reply With Quote
Bookmarks
Google
Web AF
