1998 silverado vortech Coolant leak around fittingwristman 02-23-2004, 07:05 PM I have a 1998 Silverado and there is a small coolant leak around the fitting in the front of the intake manifold. I would like some help on how the fitting is removed. Is it a quick connect fitting? Does it have a o-ring or a flare-nut type connector. Thanks tyranny 02-24-2004, 09:16 PM If it is a 5.7L, remove the pipe by squeezing the tabs and pulling the pipe out. then use a 1 1/8" wrench to remove the connector from the manifold, but be careful, those have a tendency to break off. then they are a real chore to drill and tap out the manifold. they are sealed by a pipe threading and thread sealant with an o-ring type seal that seals the pipe to the connector vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
