Rear Brakes Stuck on!Jimmy98 02-23-2004, 01:25 PM I'm having problems with my rear brakes. It's a 1998 with rear discs. The calipers seem to be sticking after the brake is applied. Sometimes it gets so hot that you can smell it burning. Does anyone know how to unseize the caliper? wombat69420 06-10-2004, 11:35 PM Ive heard that you can try applying the brakes in reverse several times. but i dont know about that, If I were in you position the calipers would go in the trash! Otherwise your just putting a bandaid on a cut that needs stiches. Green98Jimmy 06-11-2004, 11:00 AM I would replace the calipers and rotors. I had a 91 Lumina did the same thing. There was a class action lawsuit against gm. I got a wopping 26 dollars. I was told if you use your parking brake on a regular basis it will help the rear calipers to not lock up. Just don't use it in the winter because the pads can freeze to the rotors. Had that happen on a 85 MR2. G.M. seems to have a problem engineering better systems. Like the caliper problem they also can't or won't make a windshield wiper system that does'nt need a new circuit board or motor in a year or two. If your has'nt gone bad yet if it does they won't fix it. I know that 98 jimmys are'nt part of a recall for wiper circuit boards even though it is the exact same part that is on recall for other years. And they wonder why people are buying Japanese and korean vehicles. Go figure. Automotive Network, Inc., Copyright ©2012
