Speedometer - cable or sensor?
Google
Web AF
theedge981
02-22-2004, 06:57 PM
Having trouble with the speedometer on my 97 GT...just curious if the speedometer is cable driven or sensor driven.
Thanks!
amac209
02-24-2004, 03:01 AM
sensor
Markgase2000
02-24-2004, 11:25 PM
did you put on under or over sized tires?
whats the speedo doing , is it not acurate or not working altogether?
theedge981
03-03-2004, 10:32 PM
Sorry for the delayed response - no, the tires are the correct size for the car...here's what the speedometer does..although it is extremely unpredictable.
When I accelerate, usually during a hard acceleration like an on ramp, the needle will work ok up until 45 or 50, then stop, then JUMP to 57, stop....then JUMP to 65....then start working again. If I give the dashboard a swift pound of the fist, then the needle jumps to where it should be and the problem goes away...til the next time I accelerate hard. Note: I have had this problem under smooth accelerations as well, makes it hard to pinpoint when it happens.
amac209
03-03-2004, 10:47 PM
try unplugging the instrument cluster and bending any loose conectors at the harness a little to tighten the conection. if that doesn't help you'll probably need to send it out for repairs.
Google
Web AF
