95 Pathfinder Gauges Cut out...
ksull1123
02-21-2004, 05:57 PM
Hi,
My 95 pathfinder's speedometer and tachometer will all of a sudden drop to 0, while im driving. the temperature gauge will also drop below and while this happens the blinkers will not work. As suddenly as this happens, they will all go back to normal, but there is no reason why, that i can find. Any help with this would be GREAT. Hoopstar11@comcast.net is my email.
NissanZFan
02-08-2005, 09:52 AM
I have a similar problem with a 95 path. 2WD auto.
Except my meter fuse blows and the same gauges go to zero as soon as I take it out of park.At which point the automtic will not down shift and runs rich until until I replace the fuse. Getting code 14 on selfdiagnosis and disconnected each connection to the transmission till the 8 wire hooked to the passenger side of automtic stop the fuse from blowing. Not sure if this is the Vehicle speed sensor or not as have not found a pic yet. Also even without blowing fuse the turn signals do not work, but the door buzzer? sounds when I try to signal. Anyone got an idea ? jonleconey@juno.com
