need help with amp install!!!!ugotburned 02-20-2004, 08:34 PM I am trying to install my amp into my 350Z and i don't know how to take off the middle unit....are there screws i need to take out or are there just clips? i've taken out the air conditioning unit and two screws at the bottom below the head unit. i don't want to pull the entire unit out and break it so what should i do? zrated 02-21-2004, 05:27 PM do you have the 350z manual? RAREROD74 07-01-2005, 10:30 PM I am trying to install my amp into my 350Z and i don't know how to take off the middle unit....are there screws i need to take out or are there just clips? i've taken out the air conditioning unit and two screws at the bottom below the head unit. i don't want to pull the entire unit out and break it so what should i do? why are you going through all of that because the 350z is wired for sat radio and the harness is in the right rear c pillar you can use the ignition on circuit to run your remote and use a line adpater to run your speakers sense the factory radio doesnt have rca outputs Automotive Network, Inc., Copyright ©2012
