Emptying and removing gas tankTremon123 02-19-2004, 10:08 PM I need to empty out the gas tank to install the fuel pump in my '98 Blazer. What is the best way to empty it? Evidently my gas tank does not allow for siphoning. Yikes, I just filled the tank. Anyone have a great suggestion? zeeb 02-20-2004, 06:35 PM Well, I guess you don't want to drive a hole in your tank :) What you could try is to get a cheap inline pump like you would use on an older model car (I think these can be had for $19.00 to $25.00 at any generic parts store) and plumb it into the fuel line along the frame..perhaps remove the fuel filter and attach the pump temporarily with a piece of hose, and use the cheapo pump hooked to your battery to pull the fuel out of the tank into a bucket or gas can. (keep everything on the ground to avoid static). I think the fuel will flow through your old pump and as you are replacing it anyhow, you don't have to worry about hurting anything. Remember when you replace your pump to replace the strainer at the bottom and put in a new fuel filter while your at it. The only other way I have done this is to use a good floor jack with a wide top on it to lower the full tank to the ground then after removing the sending unit drain the gas out through that hole. Good luck amac209 02-20-2004, 08:18 PM if you pop off the fuel filler hose at the tank there will be plenty of room to stick in a chunk of garden hose and siphon the tank. an aquarium squeeze pump should fit past the valve or as mentioned above an electric high output fuel pump works good with 3/8" rubber line. ofcmlong 02-20-2004, 09:14 PM actually if your old pump still works you can disconnect the fuel line at the fuel filter turn your key to the on position and let your electric fuel pump do all the work. Just make sure you put a bucket or something under the open line. Automotive Network, Inc., Copyright ©2012
