Hard to get ECU codes - 92 Sentra 1.6LTony N. Vina 02-17-2004, 07:04 PM The ECU in the 92 Sentra is mounted below the center console with the mode switches inaccessible because they are against the firewall. How do I get the codes without an expensive code reader. Does the ECU need to be removed for acces? nacho_nissan 02-17-2004, 10:38 PM i think you need to remove it, not sure, hope someone can clarify! travishubble 02-20-2004, 12:46 AM The ECU in the 92 Sentra is mounted below the center console with the mode switches inaccessible because they are against the firewall. How do I get the codes without an expensive code reader. Does the ECU need to be removed for acces? I have a 92 nissan sentra 1.6, and I was able to access the ECM today with only a screwdriver. The Chilton's manual is actually not too bad for this. You remove the passenger side lower console panel (1 screw and one psuedo screw). The ECM is then exposed. You don't need to take it out. Just reach around to the back of the ECM and turn the screw (it's on the back right) clockwise, then wait 2 seconds, then counterclockwise. The car ignition must be on, but the car should not be running. The red light on the right side of the ECM will flash long for the first number, then short for the second number. For instance, long, long, short, short, short would be 32. The codes are 11 Camshaft position sensor 12 mass air flow sensor 13 engine coolant temperature sensor 14 vehicle speed sensor 21 ignition signal 31 engine controle module 32 EGR function 33 Oxygen sensor 35 EGR temperature sensor 43 throttle position sensor 45 injector leak 55 no malfunction detected I hope this helps. Tony N. Vina 02-20-2004, 04:02 PM Thanks Travis. It seems easier than what I thought. Is the screw on the rigth side of the box or on back side (front of car)? The last one would be difficult to see or access. Tony travishubble 02-21-2004, 06:04 PM Thanks Travis. It seems easier than what I thought. Is the screw on the rigth side of the box or on back side (front of car)? The last one would be difficult to see or access. Tony The screw is on the back side of the box (front of car). The light is on the right side (passenger side) of the box. The screw is a little tricky to see, but it is near the back right corner which makes it fairly easy to access from the passenger side. There may be a thin sheet of plastic over the screw which you would need to puncture. Automotive Network, Inc., Copyright ©2012
