tropper running on 3 cylinderschrisxr3i 02-17-2004, 12:13 PM Has anyone come accross 3.0 ltr diesel turbo engines running on three cylinders and smoking excessively. We have changed the cylinder head put the problem was no better than before. Any help would be gratefull. fox74 02-18-2004, 01:30 AM Have you done a comperssion test , you have stuck rings. chrisxr3i 02-20-2004, 06:15 AM Have you done a comperssion test , you have stuck rings. yes and there ok. it's worse when you put water in than without. jb4x4trooper 06-05-2004, 12:56 AM ck the injectors, the one for that cyl. could be blocked. rodeo02 06-05-2004, 07:59 AM Assuming it's an OHC engine, make sure you have the valve timing set properly after the cylinder head R/R. G/luck Joel Automotive Network, Inc., Copyright ©2012
