Theft light comes on....car doesn't start, just cranks!IIcrazedIl 02-16-2004, 10:10 PM When starting the car the theft light comes on and the car just cranks but does not start!! It's a 1996 Grand Am. Does this have anything to do with the ignition or is there anything else that can be checked? surgicaltech 02-18-2004, 06:02 PM According to the dealership repair manual, it could be either the passlock,ecm,or the instrument cluster. all 3 of these could prevent the car from starting.. IIcrazedIl 02-18-2004, 07:30 PM According to the dealership repair manual, it could be either the passlock,ecm,or the instrument cluster. all 3 of these could prevent the car from starting.. the passloch was changed now the light comes on and blinks surgicaltech 02-19-2004, 07:47 PM OK, just leave the key on for ten mins. the light should be on steady, once it is it's ready to start... F.Y.I. hook up a battery charger... IIcrazedIl 02-19-2004, 08:36 PM OK, just leave the key on for ten mins. the light should be on steady, once it is it's ready to start... F.Y.I. hook up a battery charger... the light is always steady and it wont start IN THE ZONE 02-19-2004, 11:45 PM I had the same problem, took it to the pontiac dealer and they said it was the ignition switch from a recall. They said the switch had 2 burned sensors in the switch! REPLACED FOR FREE! We will see, so far so gooooood! jerzeygrl 02-20-2004, 02:14 PM turn the ignition switch to on for about 10-15 min. When the light starts to blink or ding, remove the key. Then get someone to jump your car or a battery charger and it should start right up. don't forget to remove the key before trying to start it up again. IIcrazedIl 02-20-2004, 05:11 PM i have tried that .had it programed 2 times still come on.sometime it comes on when the car is running surgicaltech 02-20-2004, 06:04 PM i have tried that .had it programed 2 times still come on.sometime it comes on when the car is running I'm just wondering if it's not another bad passlock.... :2cents: IIcrazedIl 02-20-2004, 07:16 PM i said the same took out and returned gave me another same surgicaltech 02-20-2004, 10:33 PM i said the same took out and returned gave me another same Well,like I said before,according the the shop manual, it could be the instrument cluster,or ECM.. Just a thought.. IIcrazedIl 02-22-2004, 05:07 PM if i leave the car in netural i dont have the problem bouches 02-03-2005, 08:40 AM I had the same problem and they finally replaced the Passlock vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
