Need help on what to do/look for 4.3L
Google
Web AF
Hurst25
02-16-2004, 04:03 AM
I picked up a project S10 Blazer (see previous post) and found out that it has been sitting for the last year. When I drained the oil about 1/2 Gal of coolent came out before any oil. First, What are the probible causes, Blown head gasket? Second, what are the chances of me not having to rebuild the whole motor? Third, When I pull the oil pan tomorrow, is there any thing spacific to look for or do?
Any help would be helpfull!!!
rlith
02-16-2004, 08:19 AM
More than likely a blown head gasket... when you pull the oil pan, check the bearings, if they are cut, you will need to rebuild the motor...
Hurst25
02-16-2004, 01:17 PM
What do you mean "cut"?
skotmxpx
02-16-2004, 03:03 PM
You should be able to see if something is obviously not right. By cut I think he means engraved or ridges dug into the bearings.
rlith
02-16-2004, 03:47 PM
Correct... Any marks, even if they look like it's just surface, means that you will have to do a rebuild...
Hurst25
02-16-2004, 10:58 PM
Thanks.
Also, do I realy have to lift the engine to remove the oil pan. I don't realy have a cherry picker or anything to do this with.
Buy the way, I realy appreciate all the info!
rlith
02-17-2004, 06:02 AM
Yep, you have to lift the engine, no way to get the oil pan off otherwise...
Hurst25
02-21-2004, 11:10 PM
found out yesterday that the truck started having "issues" when the owners cousin removed the Breathalizer/Interlock device for him after he didn,t need it any more. what are the chances that an improperly removed Interlock device could cause the Blazer to run poorly and stall/not start? I'm thinking pretty good! The problem is that I don't know how those things work or what systems they hook up to. :banghead:
Any help on this one would be great!!!!!!!!!!!!
rlith
02-22-2004, 08:37 AM
Hmm, the only thing it could be in a case like that is a bad ground or blown ecm
Google
Web AF
