Re: powerstroke problems
Hmm.
Lets start off with how this system works. The oil pump (engine oil pressure) supplies oil to the internals of the engine, and the HP oil pump. The HP pump has a reservoir as part of it's mounting. The ONLY way to "prime" it, is to fill the reservoir by removing the 1/8" NPT plug on top of the gear housing near the upper rad hose. The HP pump supplies oil to the injectors. The pressure is controlled by the ICP (Injection Control Pressure) Solenoid. If it does not get +12Vdc, the engine will not start. If it sticks open, it will not start. Without a pressure gauge and a special "T" fitting rated for in EXCESS of 3000 PSI, you cannot troubleshoot the HP system very throughly.
Now, does your tach move while cranking? If not, replace the Cam (CMP) Sensor.
Do you get voltage to both sides of the glow plug relay with the "Wait to Start" light on? If not, replace that relay.
The MOST common reason for a no-start is the glow plug relay, the second is the CMP sensor. Aside from that, if it has fuel and oil, it should start.
