Rear Sway Bar Link for HX model
Ryan006
02-14-2004, 12:54 AM
Having Problems finding a rear sway bar link kit. Have an Eibach sway bar system, replaced the lower control arms. Have tried 99 Si link kit and several others. The bolt section that attachs the sway bar to the lower control arm are long enough to go completely through the lower arm. HX models do not come with a factory rear sway bar. Anyone have any suggestions???
SilverY2KCivic
02-15-2004, 12:37 AM
Sell the Eibach rear swaybar, and replce it with a Civic Si rear swaybar. Then get the subframe mounting brackets for it. Simple fix, and you'll end up ahead $$$ wise.
Also, didn't your Eibach bar come with its own links? You should be able to use those. What lower amrs did you replace with?
