idle problemgsxrvmax 02-14-2004, 12:46 AM I have a 97 LX. My idle jumps around sometimes to about 450-750 and the car viberates bad. I just did a tune up (rotor, cap, wires, plugs). Everything looked good too. Also there is a small skip in the motor about 2,500rpm. Dont know if the problem is related. I haven't noticed a pattern with any of these problems. What does it sound like?? ajdragonf 02-15-2004, 12:56 AM Sounds like it could be an intake and filter problem. Did you recently replace an OEM intake? Otherwise it could be something with the timing. My car did some strange things when the filter got messed up. I cleaned it out and dried it, now it's fine. Go figure? gsxrvmax 02-16-2004, 11:08 PM I know the air filter is clean, everything is stock. So many its a timing problem?? Gold'n 02-17-2004, 02:18 AM Might be the power control module or the Idle , air control module. You'll need a multi meter and a voltage spec guide to find out for sure. My90AccordEx 03-08-2004, 04:17 AM I have problem with my accord idle. What do I need to check to make they are workig right? vtec accord96 03-08-2004, 11:19 PM It is the timing. Cause mine did the same thing. So just go get ittimed and it will be done with. ProMan 03-09-2004, 11:13 PM If the idle rpm jumps up and down irregularly, it could be your temp sensor. Automotive Network, Inc., Copyright ©2012
