95 w idle problemnogoodblazers 02-12-2004, 07:01 PM what a p.o.s..nothing but problems..it idles ruff when warm... i have replaced a bad cmfi...new plugs..not bosch..new cap wires..and even a new distributor...it was bad...new o2's..new egr..and iac..nothing comes up on a scanner no check engine...im getting frustrated with this..any other opinions would be greatfull... Bronco2 02-12-2004, 07:31 PM Did you replace the fuel lines in the plenum with the cmfi? They have been known to leak. Have you run a compression test? Have you checked for vacuum leaks?(including the power brake booster).I don't mean to sound like a A/H,but it seems like you have been throwing parts at the car without doing some basic diagnosis. nogoodblazers 02-14-2004, 08:34 AM all the parts that have been "thrown" at it were in need of replacement... and i did not think of the booster...thank you..i will check that... mjohn 02-14-2004, 09:56 AM Also, check those internal fuel lines...fuel pressure? Jboullion 03-31-2004, 02:29 PM Mine is having idle problem after warming also. Just rebuilt from piston wedging in cylinder. Mechanic friend unplugged knock sensors and problem almost disappeared. Picking up 2nd sensor today to finish installing. Hopefully this will work. Automotive Network, Inc., Copyright ©2012
