Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nova
Old 02-12-2004, 04:58 PM   #1
big dwag
big dwag Normal reputation
turbo 350 transmission
Has anyone had this problem before? i have a 350 turbo trans that leaks from the front rightside of it. i've checked the lines bolt to the pan and they are all tight, plus i put two new gaskets on it but it still leaks all of the fluid out if its not driven for a couple of days, I don't know what else to do.
big dwag is offline   Reply With Quote
Old 02-12-2004, 06:03 PM   #2
Bronco2
Bronco2 Normal reputation
Re: turbo 350 transmission
Isn't that the corner where the dipstick tube goes in? Guessing bad O-ring on bottom of tube,running down and looking like a pan gasket leak. Also,include model,make,year,engine,etc. with your posts and you will get better answers. BTW-checked your profile-your a "studant"?
Bronco2 is offline   Reply With Quote
Old 02-12-2004, 08:10 PM   #3
big dwag
nope no its not the o-ring from the dipstick i've checked it. chevy nova 75-357 motor.
Old 02-13-2004, 07:02 PM   #4
Bronco2
Then my best advice would be add a flouresant (? ) dye to the trans and check it with a blacklite. You may have something wierd going on,like a cracked or pourous trans. case, the front pump seals may be leaking,etc. The trans pan may be bent enough not to seal.
Old 02-14-2004, 09:20 AM   #5
big dwag
I was thinking the same think about it being cracked,i know its not the front seal because its new and that would leak from the dust cover ( a hole in the bottom of it), so i'll check it again for a crack, hope it not because i don't want to take it out.
Bookmarks
Google
Web AF
