Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Escort
Old 02-12-2004, 09:11 AM   #1
escortLX361
escortLX361 Normal reputation
How can I make it faster?
I just want to know how to make my 95 escort LX faster without spending my ass off.
escortLX361 is offline   Reply With Quote
Old 02-12-2004, 10:00 AM   #2
xjoeharperx
xjoeharperx Normal reputation
Send a message via Yahoo to xjoeharperx
Re: How can I make it faster?
I would see if you could find the 1.8L gt motor for that car.. its made by mazda and is found in the escort gt and mazda protege, its a good starting point...
xjoeharperx is offline   Reply With Quote
Old 02-12-2004, 03:01 PM   #3
escortLX361
I would if I could but I just bought the car and I don't think my dad would be to happy about me swapping engines. But is there any other stuff I can do? I know some stuff about cars but I'm hoping to learn more. If there's anything you can tell me like exhaust or intake or other small stuff I can do I would really appreciate it
Old 02-12-2004, 05:37 PM   #4
xjoeharperx
Check around with the aftermarket suppliers, i dont recall much of anything that was made for that motor..it wasnt a hot performance car...most of the performance mods are for the 98 and up cars, and there are very few of them....any power building is probably going to have to be internal modifications $$$$$$....there are a couple of people that have put a turbo on the motor but im sure that wasnt cheap ethier.
Old 02-12-2004, 07:16 PM   #5
escortLX361
Okay. thank you for your advice. I have another question though. Would autozone or pep boys have anything? And also my sliding seat belt buckle isn't working and the thread I made for that subject isn't getting any replies. can anyone here help?
Old 02-13-2004, 11:45 AM   #6
xjoeharperx
The seatbelt has a lifetime warranty from the manafacturer..gov says they have to stand behind the safety equipment....go to the dealership and have them fix it for you..
Old 02-13-2004, 02:40 PM   #7
escortLX361
Even If I bought the car from a used car dealership without warrenty? What dealership would I take it to? Any ford dealership? or is there a certain type?
Old 02-14-2004, 10:39 AM   #8
xjoeharperx
any ford dealership will do
Old 02-16-2004, 02:59 PM   #9
escortLX361
Okay cool thanks. And one more thing. How do I take off my headlight lenses I looked at it and II can't get the headlights off. can you help?
Old 02-16-2004, 03:50 PM   #10
xjoeharperx
if you are trying to change the bulb, look at the back of the light and you will see a ring with a wire harness in the middle...take the harness off and grab the ring and turn it to the left..the lamp will come out once you get the ring off..dont touch the new bulb with your fingers or it will burn out in a vary short time....if you are trying to take the lens off to change it, look behind the light and you will see the headlight body that the lamp is located in ...that whole assembly has to come out as one piece....im not sure if you can change the glass, or if you have to get a whole new assembly...some cars do , some dont...
Old 02-16-2004, 07:28 PM   #11
SouthernThunder
SouthernThunder Normal reputation
I have a 95LX and I had the cam set up 2 degrees and a racing clutch installed and the linkage set up as far as it would go without buying new linkage(to give it faster shift points) and had a flowmaster exuast system put on with no resanator and a gutted cat. and got an edlebrock intake with venom fule rail and injectors. and I now can out run crx and civics(none turbo or nitros) and I've out ran one 305 camaro but I think that was because that dude just couldn't drive(just some suggestions)
SouthernThunder is offline   Reply With Quote
Old 02-17-2004, 11:13 AM   #12
escortLX361
Thank you for your help. Is there any other tips or anything you wanna tell me?
Old 02-20-2004, 01:43 PM   #13
jeffescortlx
jeffescortlx Normal reputation
Send a message via AIM to jeffescortlx
There's a ton of stuff you can do to a 1.9 Escort, your just not gonna find much aftermarket parts. Go to www.escortracing.com and look around the chat room.
There's: headers, UDP, chip's, clutch's, turbo's, N20, intake's, exhasust systems, cams, motor swaps, throttle body's, body kit's, lowering springs, coil overs...the list goes on, you just need to find them.
I make slow Escorts less-slow.
My cardomain
jeffescortlx is offline   Reply With Quote
Old 02-20-2004, 01:56 PM   #14
jeffescortlx
Re: Re: How can I make it faster?
I'm not trying to be a dick, but your clutch, fuel rail and injectors did'nt make you any faster. The stock injector can support about 120hp. The stock fuel rail is good to about 250hp. Adding fuel with out adding air does not increase power.
A gutted cat and aftermarket muffer only adds about 5hp, unless you have a header than it could be around 8-10hp total.
A aftermarket clutch in only really needed at around the 130hp mark, even then I know of ppl to use the stock one at 180hp.
Your cam and intake proby made the most difference. The cam could add 10-15 hp, and intake/cone filter adds about 3-5hp.
A stock 91-96 1.9 lx (5 speed) puts down about 79-80 wheel hp, with a cam, intake and muffler your probly at about 95whp.
My cardomain
Old 02-20-2004, 09:55 PM   #15
bigrod118
bigrod118's Avatar
bigrod118 Normal reputation
Send a message via AIM to bigrod118 Send a message via MSN to bigrod118 Send a message via Yahoo to bigrod118
Re: Re: Re: How can I make it faster?
well, the first suggestion was a good one, the motor. I have the 1.8 maxda in my gt and it puts out 127hp stock. a thing you could get for under $200 in a k+n air filter, I felt the increase in power. more air will make it faster, but you wont just start winning races. I haev a good web site you might want to check out, deals with a few cars directly and the escort is one of them. intakes exhausts, tons of shit.....www.corksport.com
bigrod118 is offline   Reply With Quote
Bookmarks
Google
Web AF
