blinkers
Aleromommy10
02-11-2004, 09:13 PM
my blinkers some times stop working what do i do?
demanufactured
02-11-2004, 11:20 PM
sounds like you have a lose wire or bad connection ect ect....im sure a mechanic could fix ya up. Hopefully they wont charge too much.
beaverpants
02-23-2004, 07:56 AM
this happened to me.
the 4 way blinker button died. you know the glowing red button. id have to wiggle it to get my turn signals to work. .. just simply pull it out. get a new one, i also took out the trip around my gages to gain some access
kazoobers
03-07-2004, 09:51 PM
What do you mean simply pull it out and get a new one? My blinker (sound) goes on by itself once and awhile, especially just after the turn signal just goes off. Can you replace the blinker relay switch just by replacing the hazard light? Can you get the hazard light out just by pulling on it from the front, or do you somehow have to get in from the rear of the instrument panel?
Thanks.
JTrujillo86
03-07-2004, 11:55 PM
DON'T DO ANYTHING YOURSELF - GM has issued a recall for this defect. Take it to your local OLDSMOBILE dealer and they'll get a new unit installed for you. This effects model years 1999 thru 2001. Check this out at the NHTSA's website. They list recalls and TSB's for your vehicle.
Good luck -
Jeremy
beaverpants
03-08-2004, 12:40 AM
Thanks.
the hazzard light IS the turn singnal relay.. and the hazzard relay all in one 3" long green blocky thing .. pulls out and is the hazzard button
godfathers10
03-11-2004, 07:44 PM
just so you know after speaking to gm only some of the Aleros are recalled for this wich is stupid since they all have the same switch you have to give them your vin to find out if your car is covered. only cars manufactured at certain plants get the recall based on the # of complaints they get. so in other words hang on to your reciets incase they do recall your vehicle. sometimes it helps to complain!
