Programming a second Keyless Remote
The Nacc
02-08-2004, 03:58 PM
Hi guys
I am trying to program a second keyless remote for my 2001 3.5 litre.
First of all can anybody help me with the procedure so I can do it myself. I read a few posts on the subject, but none seem to be for a 2001.
Another dumb question is where is the DLC on the 2001 and what does it look like.
Looking forward to a reply
Thanks in advance
The Nacc
Marc_Aurora_2001
02-08-2004, 08:36 PM
The Nacc....The following instructions for remote programming are from
the 2001 Aurora shop manual. You need a scan tool for this.
http://img.villagephotos.com/p/2003-3/138085/remoteprog.jpg
_______________
GM!!! SAVE OLDS!!!
The Nacc
02-10-2004, 01:09 AM
Thanks Marc Aurora 2001
That procedure looks pretty official.
I came across something in another board yesterday that talked about a "fused jumper wire" and the 4th and 8th input on the data line connector.
Is a "fused jumper wire" have the same purpose the same as a scan tool that you mention.
The procedure it mentioned was almost the same one as in the arcticle you mentioned only it used a "fused jumper wire" and the 4th and 8th input on the data line connector.
Have you heard of this. And does it work
Thanks in advance
The Nacc
Indy8
02-10-2004, 12:34 PM
It does the same thing. They state the use of the scan tool to get you into the dealer.
Marc_Aurora_2001
02-10-2004, 04:16 PM
I knew about connecting those 2 terminals, but I always thought that
that was for the 1995/99, and not the 2001/03.
________________
GM!!! SAVE OLDS!!!
Lee Must
03-04-2004, 01:39 PM
Hi Guys,
I have a question about the remotes.
All functions work on both of mine (1997 Aurora),
except the unlock and also when I put the car in Park and shut down the engine, the doors do not unlock then, either.
Is there a way to program, that function back in, or is it another problem?
BrianC974
03-04-2004, 02:26 PM
I'm a tech at a Olds dealer. You can't ground the pins on the DLC on the Aurora to enter program mode. Works on some GM's, not the Aurora. You need the Tech 2 scan tool, take it to the dealer, you're only option.
Lee Must
03-05-2004, 09:33 AM
I guess I found out that, my problem isn't in the remote, but some place else, The unlocks don't work when you put the car in park...
Thanks, Lee
KillerKeller_jr
03-05-2004, 07:52 PM
Hey Brian, gonna have to disagree with you but I sure got it to work on my Aurora (1995) and I just grounded the 4 & 8 terminals and it worked great. Saved about $200 compare to taking to the dealer. I am unsure if the same thing works for the 2001 but pretty sure according to the forums I've read here. Any one know for sure?
Indy8
03-08-2004, 03:48 AM
I jumped them on my 97 too. The lock/unlock options can be set without the remotes as called out in the owners manual.
Spinman
03-20-2004, 11:02 PM
I was able to set my '96 using a fused jumper wire - with instructions found on the Forum. Worked great. (Also found the instruction on ALLDATA - just to be sure).
