Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Nonspecific
Old 02-06-2004, 03:11 PM   #1
Gnavicks
Gnavicks Normal reputation
Question 93 VW Fox Won't Stay In Reverse At Times
Hello All,
I've recently been having trouble with my reverse in my manual '93 WV Fox. On occasion I'm able to hold my shifter in reverse and go on flat surfaces, but backing up hill is out of the question. I'm wondering if there is a possible solution to my reverse problem. I was thinking it might be a bent shifter rod, or a stripped reverse gear. If anyone knows of an easy way of repairing either of these it would be greatly appreciated.
Thanks,
Dalton
Gnavicks is offline   Reply With Quote
Old 02-06-2004, 04:06 PM   #2
boschmann
boschmann Normal reputation
Re: 93 VW Fox Won't Stay In Reverse At Times
On older VW's popping out of reverse was a common transmission problem, but I haven't heard of it on a Fox before. More common on Foxes is shifter linkage alignment issues. If it feels like it fully engages reverse (compare the feel to that of another gear that works properly) then is pushed back out, it's probably inside the transmission. If it never seems to fully go into reverse it's likely the linkage. Unfortunately, to properly adjust the linkage requires a special VW tool, basically a template. I haven't seen a dealer that still has one either. I have been able to get it close enough to work without the tool, but it was difficult and basically was trial and error positioning. The shift rod has an adjuster that both can be rotated on a spline and would slip in and out depth-wise.
boschmann is offline   Reply With Quote
Old 02-16-2004, 08:54 AM   #3
noodle32
noodle32 Normal reputation
Sounds like you may need a new reverse bushing - if you can I would check out car-part.com to see if you can get a deal on a 5 speed tranny (that is if you have a 4 speed - better economy and you don't have to press down and lean it towards 1st to get it to go into reverse either!) But it may just need a new bushing - common prob for this type of tranny - happened to me too
noodle32 is offline   Reply With Quote
Bookmarks
Google
Web AF
