1999 dodge caravan resistor board for blower location
Google
Web AF
kesystems
02-06-2004, 10:07 AM
can anyone tell me the location fo the blower resertor board. My blower only works on high and I think the resistor board is the fault.
Thanks
Fred
ccardoso
02-06-2004, 11:27 AM
I have the same problem on my 2001 Caravan. If you figure out the problem, please post the solution. Thanks.
rodeo02
02-06-2004, 12:30 PM
I'm not familiar with the '99, but the resistor pack is typically mounted under the dash in the blower duct (for cooling purposes), or near the HVAC controls. Try to follow the wire harness from the blower speed control switch, that will lead you to the resistor board/block.
G/luck
Joel
Ghostman
02-06-2004, 10:15 PM
The resistor block is located on the passenger side of firewall under the hood. The resistor block is pried out of its location under the wiper module, you may or may not have to move the wiper module to get it out.
ccardoso
02-09-2004, 08:09 AM
I just finished replacing the blower resistor block on my 2001 Caravan. It was located on the blower motor which is located directly behind the glove box, on the passenger side.
pcv
02-09-2004, 10:54 PM
Drop the glove box and you will see it.
johnnyd
02-10-2004, 05:41 PM
It's exactly where Ghostman said on my wife's '99 grand voyager. just pulled it out today and replaced it. $13. the old one had a break in the shortest element. now the low speeds all work.
johnnyd
helinut222@msn.com
02-12-2004, 06:11 AM
I have a 97 and the blower only worked on high. It was located right behind the passenger side shock tower. Its a pain to get your hand behind there to pull it out. The pins in the pulg on mine were all rusted and I had to cut the wires to get them apart. I went to a junk yard that had a bunch of Caravans and took a hole plug from one of those. I think it is a common problem because several of the vans I looked at were also rused together.
panik88
06-07-2009, 02:25 PM
I have a '99 and found mine on the firewall passenger side. I pulled it out and found that the shortest element was corroded away. But since I am somewhat broke I had to do a bit of repair to the element ( yes I know 13 is not much but when you have no money it's alot) Anyway I wrapped the wire around the other one that shared the same terminal and soldered it and so far it seems to be working for now. :smokin:
Google
Web AF
