toyota camry TSB's
mm1997
02-05-2004, 09:38 AM
Does anyone subscribe to alldata to get the Tech Service Bulletins (TSB)
for a 97 98 or 99 camry?
I am looking for TSB - EL008 - 98
and TSB - BO013-98 and TSB - SU00796
Any help would be great!!
NO any help would be Awesome!!!
Bossman
02-07-2004, 06:40 AM
Hello,
You don't need to be a subscriber to alldata.com to obtain the Technical Service Bulletins (TSB). Just punch up their web site and click on the appropriate links.
I've pulled up and printed out the lists of TSB's for both my 92 and my 03 Camry; no problem at all. :smile:
mm1997
02-09-2004, 07:51 AM
The tsb titles are free to look at but you cannot see the actual report unless you pay for a subscription. I dont know what you are talking about? Can you be more specific?
yotatechie04
02-10-2004, 12:23 AM
TSB Number Issue Date TSB Title BO017-01 JUN 03 Interior - Power Seat Inoperative/Loose EL008R-02 FEB 03 Keyless Entry - Transmitter Programming & Identification EG003-03 FEB 03 Exhaust System - Sulfur Smell EL008R-02 JAN 03 Keyless Entry - Transmitter Programming/Identification EL003R-00 DEC 02 Instruments - Speedometer/Tachometer Needle Movement PG027-02 DEC 02 Steering/Suspension - Ball Joint Inspection EG013-02 JUL 02 Emissions System - MIL ON/DTC's P0440/P0441/P0446 Set BO010-02 MAY 02 Child Restraint - Seat Top Strap Installation EG003R-02 MAR 02 Emissions - OBD II Readiness Monitor Drive Patterns EG007-02 MAR 02 Valve Cover Oil Baffle - Damage Prevention SU001-02 MAR 02 Rear Hub Bearing O-Ring - Service Tip PG008-02 JAN 02 Certification Label - Replacement Availability PG009-02 JAN 02 VIN Plate - Replacement Availability ST008-01 DEC 01 Front Suspension - Squeaking Noise BO030-01 DEC 01 Windshield Wiper Blade - Maintenance and Cleaning BO026-01 OCT 01 Seat Belts - Shoulder Anchor Tape Set BO025-01 OCT 01 Interior Trim - Sun Visor Vanity Mirror Broken/Damaged BO020-01 AUG 01 Sliding Roof - Diagnostic Tips EG005-01 APR 01 EVAP System - Supplemental Operation/Diagnostics EG004-01 APR 01 MIL ON - DTC P1133 Updated (Oxygen Sensor Circuit) BO011-01 MAR 01 Seat Belt Tongue Plate Stopper - New Parts ST001-01 FEB 01 Steering Wheel Nut - Torque Standardization BO002-01 JAN 01 Seat Belts - Extenders BO028-00 NOV 00 Trunk - Water Leaks BR004-00 OCT 00 Brakes - Pad Clicking Noise EL011-00 OCT 00 Daytime Running Light - Disabling Procedure AX007-00 SEP 00 Alloy Wheel - Identification and Application ST004-00 JUN 00 P/S - Power Steering Rack Squeaking Noise ST002-00 MAY 00 Repair Manual Corrections -Torque for Steering Wheel Nut SU002-00 MAY 00 Suspension - Rear Axle/Shock/Coil Reminder, ABS BO009R-00 APR 00 A/C - Loose Center Vent Adjustments EL007-00 APR 00 A/C - Heater Control Assembly Instructions AX003-00 MAR 00 Antitheft - Trunk Courtesy Connection Standardized PG006-00 MAR 00 Emissions - CA/50 State Certified Emission Control Label NV007-00 MAR 00 Mirrors - Wind Noise from the Door Mirror BO015-00 MAR 00 Mirrors - Installation of Door Mirrors AX001-00 MAR 00 Vehicle - Towing Guide. BO009-99 MAR 00 A/C - Loose Center Vent Adjustment BO002-00 JAN 00 Seat Belts - Extenders Available SU001-00 JAN 00 Suspension - Front Support Change Reduces Noise PG032-99 DEC 99 Year 2000 Readiness Disclosure BO020-99 DEC 99 Seats - Bottom Cover Looseness BO021-99 DEC 99 Sunroof - Inoperative BO017-99 NOV 99 Windows - Door Glass Displacement EL006-99 OCT 99 Antitheft - Engine Immobilizer System Cautions EG009-99 OCT 99 MIL ON - DTC P1133 Oxygen Sensor Circuit Response BO012-99 SEP 99 Windows - Door Glass Displaced BR004-99 JUL 99 Brakes - Updated Drum Reduces Groan/Howling SS002-99 JUL 99 1999 Special Service Tools EG004R-99 JUN 99 MIL ON - DTC P0446 EVAP Vent Control Circuit Defect PA004-99 JUN 99 Paint - Two Tone Color Scheme TC003-99 MAY 99 A/T - Fluid Interchangeability AX006-99 APR 99 Antitheft - Changes For GBS Glass Breakage System EG004-99 APR 99 MIL ON - DTC P0446 EVAP Vent Control Circuit Malfunction BO007-99 APR 99 Lights - Headlight Alignment Modified AX005-99 APR 99 Antitheft - Programing the Remote Control TC002-99 APR 99 Drivetrain - Revised Drive Shaft Grease SS001-99 APR 99 Antitheft - Scantool Immobilizer Key Code Utility BO005-99 MAR 99 Interior Trim - Center Console Latch Improvements AX004-99 MAR 99 Vehicle - Towing Guide PA002-99 MAR 99 Paint - Refinish Formula Codes SS003-98 DEC 98 Accessories - Rivet Nut ToolHere's the TSBs that were free for viewing on alldata.com...although it might not be exactly what you were looking for. I'm not sure anyone on here has a subscription to alldata...
mm1997
02-10-2004, 08:25 AM
Thanks for all the help,,,,,,,,,But I already know the titles of the TSBS. I want to read the info inside a couple of them. The titles dont tell you how to fix your problems. I guess I was not to specific and Should of explained better.
yotatechie04
02-10-2004, 02:44 PM
You should search on here for someone who has the alldata subscription.
adamgt
12-30-2004, 08:01 PM
Ok, I have retreived two codes from my 98 Camry
They are P0441 and P0446
Looking through Toyotas TSBs I have found them in the following;
EG003-98 APR 98 MIL ON - DTC P0441, P0446 (EVAP Control System)
Seeing how this is only a TSB I do not like my chances of going to Toyota and asking them to fix it for me free of charge.
csaxon
12-30-2004, 09:03 PM
mm1997 El008 refers to the factory installed versus dealer installed wireless transmitters programming options for various toyota models.
BO13 refers to a new fuel door hinge spring and fuel filler shield. Apparently, some wouldn't open on the first try. New spring #77360-33020 old spring 77360-22020
adamgt
12-30-2004, 11:31 PM
csaxon,
Can you get me any info on the following TSBs
EG013-02 & EG003-98
Thanks
csaxon
01-01-2005, 10:05 PM
EG013 refers to the shifting improvements to the U140E transmission through a new ECU calibration #53310200 which supercedes 53310100. It's for 6 cylinder Camry's from 2002 on.The op code is EL1015 "recalibrate ECM" .5 hour. Falls under Fed Emission Warranty in effect for 80000 miles or 96 months from vehicle in service date.
EG003 "Readiness monitor drive patterns" is 23 pages of monitor testing programs and patterns for various toyota models. It covers EGR, Catalyst, ECM, O2 sensors and air/fuel sensors and EVAP systems.
P0441 can be the result of debris in the Evaporative Emission Control System. This may cause blockage of a vapor line or a stuck VSV
csaxon
01-01-2005, 11:22 PM
Emissions System - MIL ONIDTC's
EGO 13-02
Title:
M.LL. "ON" P0440, P0441 & P0446
Models:
Camry & Solara
Under certain driving conditions, some Camry and Solara vehicles may exhibit a M.LL. "ON" with DTCs P0440, P0441 and P0446 stored due to an inoperative Vapor Pressure Sensor 3 way Vacuum Switching Valve (VSV). An improved Vapor Pressure Sensor VSV has been developed to correct this condition.
Previous part #90910-12 09 Current part #90910-12271
PART NAME Vapor Pressure Sense. VSV
csaxon
01-01-2005, 11:34 PM
adamgt
01-02-2005, 05:02 PM
Thanks for the reply csaxon;
However the SBS that I got from www.alldata.com concerns a 1998 Toyota Camry CE 2.2L 4-cyl not a V-6.
It reads
and
The check engine light came on due to the fact that my dad overfilled the gas tank. I just wanted to know if Toyota would take care of this issue without any hassles.
If they will not be able to resolve this free of charge then I will have to run some tests on the EVAP system and fix it myself.
csaxon
01-02-2005, 08:16 PM
I'm looking at genuine toyota tsb's. You're correct I used ego 13 instead of 13-02. EGO 13-02 covers all Camry's and Solara's from 1998-1999 and covers procedures to check,fix or replace the VSV with the new model number I mention above. The defective vacuum pressure sensors VSV's were causing the erroneous DTC's PO440,441 and 446. It was also noted that the vacuum hoses were defective by being malformed in the production process. The toyota op code 178011 is for 4 and 6 cylinders cars. I looked at the Alldata list for the tsb and it references a 98 4 cyl camry but the actual toyota TSB is nothing like the alldata version. Alldata tries to generalize and simplify the problem repair procedure. The actual tsb for testing these things is 23 pages long and relies on the Toyota tester. It shows graphs, expected readings and test setup procedures. Your probably out of warranty but you can check the hoses and part# of the vapor pressure switch vsv.
csaxon
01-02-2005, 08:35 PM
This is the alldata version. It is very general and the ALLDATA subscriber specified a 1998 Toyota Camry CE Sedan L4-2164cc 2.2L DOHC MFI vehicle. The actual toyota tsb is far more indepth and covers all vehicles affected not just a 98 camry ce, note the 6 cyl avalon below. Note also that the original toyota tsb mentions a new part number, the malformed hoses and far more actual testing data
ENGINE
EG003-98
April 3, 1998
Title:
EVAP SYSTEM DIAGNOSIS: P0441 / P0446
Models:
RAV4, Tercel, Paseo, Camry, Avalon,
Tacoma, 4Runner, T-100
Introduction
The following procedure is recommended for repair of MIL "ON" conditions involving confirmed DTC
P0441 and P0446.
. . MIL ON - DTC P0441, P0446
Notes
- All RAV4, Tercel, Paseo, Camry, Avalon, Tacoma, 4Runner, T-100 that display codes Vehicles
P0441 or P0446.
A. Diagnostics for PO441:
1. Remove Vacuum Hoses between EVAP VSV and Charcoal Canister and discard.
2. If there is a metal vapor pipe between EVAP VSV and Charcoal Canister, clean inside of vapor
pipe
3. Replace EVAP VSV and Charcoal Canister assembly with new parts.
4. Install new vacuum hoses between EVAP VSV and Charcoal Canister.
B. Diagnostics for P0446:
1. Inspect vacuum hoses and pipes between EVAP (Purge) VSV and Charcoal Canister for leaks.
2. Replace Vapor Pressure VSV and Canister.
NOTE :When performing diagnostics for an occurrence of a MIL "ON" condition, Diagnostic
Trouble Code (DTC) P0441 may be result of debris in Evaporative Emission Control System. This
may cause blockage of a vapor line, or a stuck VSV, as described in troubleshooting area of Repair
Manual.
adamgt
01-04-2005, 12:24 PM
csaxon
Thanks for the info.
I just picked up a Haynes Manual yesterday, I will attempt to have a go at it this weekend.
Cheers
ADam
