Guess the power
Sypherz28
02-05-2004, 01:03 AM
Take an 86 3SGE engine (stock ~130 hp)with the following:
Aftermarket pistons, crank, timming gears, cams, headers, fuel injectors
cold air intake, duel exhaust, and a port and polish
Estimate what you think the horsepower would roughly be after all of that
89Turbo944
02-05-2004, 01:08 AM
pistons 20hp, crank 5, timming gears 10(if adjusted right, if wrong then you will lose more power than you gain), cams 5-15(depends on cam profile), headers 5-15 depends on style and size of header, fuel injectors (no better unless you upgrade the rest of the fuel system), dual exhausts will make you lose power, port and polish 5 hp.
so lets see maby a 70hp gain, most likley less but you could do 200hp @ the crank.
All figures were pulled out my ass:)
Team_Omega1
02-05-2004, 01:15 AM
200hp at the most if your lucky
Team_Omega1
02-05-2004, 01:16 AM
badA$$ FD do you own that
89Turbo944
02-05-2004, 01:23 AM
NAW wish i did tho. Looking to sell the GSX and S2K to get it:)
Would be tight, and i have always loved the FD and now that i have the monwy and knowledge to own one i think it is time to get one:D
Also, i posted those numbers based on a perfect running engine. This means that you cooling system is in perfect condition, oiling system, electrical system, properly tuned for all the parts, gererly a perfect engine. So yes, you would be VERY lucky if you hit 200hp with that stuff.
But do it and see what happens, hell i may be wrong. Maby someone will post and has had that tipe of setup and has acheived good numbers. Who knows.
Good luck with it tho.
Sypherz28
02-05-2004, 01:25 AM
Oh lets tack on a dry shot of NOS to that 86 too..
Sypherz28
02-05-2004, 01:27 AM
im tryin to find the best combination of things to rebuild my engine worthy of the streets
