Keyless programmingbehnis 02-04-2004, 10:39 AM Hi, I wanna to program the only new keyless entry of my camry 98 XLE with fcc id GQ43VT7T. Can anybody assist me? I appreciate you help. Peace, Behnis Joe W 02-04-2004, 06:58 PM Search this forum as this has been addressed before and it's a fairly involved process. behnis 02-05-2004, 08:17 PM Thanks Joe, but none is specific for camry xle 98 v6 and the cars which use this FCC ID. The rpogramming should be specific for this FCC ID GQ43VT7T. By the way, If anyone know the rule for this, Please let me know. I appreciate any help. Behnis mm1997 02-06-2004, 09:31 AM I ve been trying for months to find the answer. I have a 97 with the same fcc id. Ive found the info for 2000 and 2001 and they are not the same. The Toyota tsb stating how to do it is TSB-EL008-98. This is for the 97,98,99 camry. I am to cheap to pay alldata.com for this tsb access. Im still trying to find it online. No luck so far behnis 02-09-2004, 01:12 PM This procedure works Toyota Camry XLE 98. Here you go: 1) With the key OUT of the ignition switch, locate and disconnect the power mirror control switch from the vehicle harness.(with tiny screwdiver you are able to take out the mirror switch control panel) 2) Use a suitable jumper wire (paper clip works), and connect terminal 2 (Purple wire) to terminal 10 (White/Black wire). The vehicle will cycle the locks once to confirm programming mode. If the vehicle doesn't respond - this prcendure will not work! 3) Press and release any buton on the remote. The vehicle will cycle the locks once to confirm code received. 4) Program additional remotes by repeating step 3 5) Disconnect the jumper to exit programming mode. 6) Reconnect and reinstall the mirror switch Take care salempastor 02-10-2004, 06:39 AM I ve been trying for months to find the answer. I have a 97 with the same fcc id. Ive found the info for 2000 and 2001 and they are not the same. The Toyota tsb stating how to do it is TSB-EL008-98. This is for the 97,98,99 camry. I am to cheap to pay alldata.com for this tsb access. Im still trying to find it online. No luck so far mm1997, I have the info you need--e-mail me salempastor@hotmail.com ejfl 04-15-2004, 04:41 PM I would like to program a gq43vt7t keyless remote with a dodge grand caravan from 96 if some one have an idea? thanks Automotive Network, Inc., Copyright ©2012
