Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Sentra/200SX (USDM FWD)
Old 02-04-2004, 02:22 AM   #1
93sentraSE-R
93sentraSE-R Normal reputation
Send a message via AIM to 93sentraSE-R Send a message via MSN to 93sentraSE-R Send a message via Yahoo to 93sentraSE-R
i wanna race my sentra
im new here
after my dad having THREE 91-94 sentra se-rs
i decided to get one...
i got a 1993 sentra se-r, stock with 109,000 miles
im looking forward to racing this thing...
i need to add stuff to soop it up...
any suggestions on what to do?
- 93 sr20de sentra se-r
93sentraSE-R is offline   Reply With Quote
Old 02-04-2004, 10:55 AM   #2
nacho_nissan
nacho_nissan Normal reputation
Send a message via AIM to nacho_nissan Send a message via MSN to nacho_nissan Send a message via Yahoo to nacho_nissan
Re: i wanna race my sentra
first thing...intake and exhaust. you have many choices for air intakes,get a good K&N cold air intake or any other good quality intake. exhaust... hard to pick the best. you have alot of choices with that also. i would go with JDM stuff. then you will wanna get suspension. do some searches on nissanforums.com. you have alot of aftermarket support for your car out there. in nissan forums, you will find alot of info. laterz
nacho_nissan is offline   Reply With Quote
Old 02-04-2004, 10:58 AM   #3
nacho_nissan
after you get the basics and before you go into deeper stuff, you will have to decide if you want n/a or turbo. so start thinkin bout it right now, and also if you want to auto-x,drag or whatever. make up your mind, and maybe we can give you better advice. laterz
Old 02-04-2004, 01:26 PM   #4
sr20de4evr
sr20de4evr's Avatar
sr20de4evr Normal reputation
Re: Re: i wanna race my sentra
This decision should be made before he starts anything, because if he decides to turbo then everything he just did is a waste. Forget about nissanforums as well, there are a couple knowledgable people there, but there is MUCH more info at www.sr20forum.com
If you do want to go turbo then don't mod your engine at all, it'll just be a waste. If you decide to go NA then start with an intake and header. Exhaust is really a waste, it's just for the sound and doesn't affect your hp much at all. Look to JWT for the serious stuff, you can get a set of s3 or s4 (or even c1 if you're hardcore enough, hehe) cams, and a reprogrammed ecu to match. Next should be a clutch since your stock one is probably pretty worn, while you're in there you might as well get an upgraded flywheel (makes the install much easier if you do them at the same time). The engine can take a helluva lot of power, so after you get the normal boltons, cams, etc you can add a decent sized wetshot or direct port n2o setup. Just do some research over on sr20forum and you'll get all the info you could ever want and more.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
sr20de4evr is offline   Reply With Quote
Old 02-04-2004, 08:32 PM   #5
Datsun83
Datsun83 Normal reputation
Thumbs up
Listen to him.
Only thing I gotta say is with N/A, street driving is much more civil.
Datsun83 is offline   Reply With Quote
Old 02-04-2004, 08:36 PM   #6
nacho_nissan
you should just go GTi-R SR20DET if you have the money.. you'll have 200hp stock! i'll go turbo on this,or better, swap...
Old 02-05-2004, 12:53 AM   #7
93sentraSE-R
thanks, i already have a new clutch installed because the stock was warned out.
Old 02-05-2004, 01:06 AM   #8
Serious93
Serious93 Normal reputation
Send a message via AIM to Serious93
BLUEBIRD Specifications
Displacement: 1998cc (2.0 liter)
Cam type: DOHC 16 valve, chain driven cam sprockets
Bore and stroke: 86mm x 86mm
Compression: 8.5 : 1
Horsepower: 205ps at 6000rpm
Torque: 203 ft/lbs at 4000rpm
Stock boost: 7 psi
Injector size: 370cc/min
Compressor: T-25, 60 trim 56mm BCI-1 comp.
Turbine: T-25, 62 trim 53.8mm 0.64 A/R housing.
Center Section: Journal bearings
The bluebird would be the best way to go. Parts are available from your local nissan dealer. Parts for the GTI-R will have to be tracked down in Japan which is a pain in the ass. With the bluebird motor, exhaust, and good driving, he should be mid to low 13s.
Serious93 is offline   Reply With Quote
Old 02-05-2004, 01:48 AM   #9
sr20de4evr
sr20de4evr's Avatar
The bluebird is nice, but for a little more you can get a gti-r det that makes ~25hp more and has a bit beefier internals. All sr20 parts are swappable just about, so if he wanted anything from the factory he could get it just as easily for either motor. Actually I doubt you'd find anything for a BB or GTI-R det at a local dealer, considering neither of them were ever sold in the US. The best you could do is get a part from a USDM sr20 and then put it in your det, which can be done for both models so it's a moot point.
'01 Black Sentra SE
'05 Silver WRX STi
Old 02-05-2004, 07:38 PM   #10
93sentraSE-R
should i buy an engine from ebay?
becuase theres lots of gti-r and bluebirds for sale.
Old 02-05-2004, 08:38 PM   #11
94sentragtr
94sentragtr Normal reputation
Send a message via AIM to 94sentragtr
i`ve seen ppl buy um and be really happy with um...so i guess so yeh
94 XE-basically stock
92 SE-R PROJECT BOOST
94sentragtr is offline   Reply With Quote
Old 02-05-2004, 10:16 PM   #12
sr20de4evr
sr20de4evr's Avatar
go to www.jgycustoms.com
'01 Black Sentra SE
'05 Silver WRX STi
Old 02-06-2004, 08:15 AM   #13
fugiot
fugiot's Avatar
fugiot Normal reputation
Send a message via MSN to fugiot
By the way, an upgraded(lightened) flywheel will give you a major whp boost. When I got my SE-R, I had just installed an HKS intake and it was running approximately 15.6 in the 1/4. Then I installed a 6-puck ACT clutch and an 8.5lb Unorthodox flywheel and it dropped my 1/4 time down to 14.7! These cars are beasts with very few mods, you just have to choose the right ones. I took down a slightly modded ITR and the guy thought I was lying to him for like 10 min. when I said it's a stock motor. Also look into disconnecting your EGR valve. I'm sure your dad knows about that. Other notable kills you can expect:
Infiniti G35(sedan)
Altima 3.5 SE
RSX-S
Hemi Durango
Mazda RX-8(5mph rolling start).
All Preludes and Integras that aren't modded too much.
The SR20's near-perfect power curve is just plain awesome. And the SR20VE's PERFECT power curve is so enticing that I can't help but direct all my money towards one.
fugiot is offline   Reply With Quote
Old 02-06-2004, 10:08 AM   #14
carrrnuttt
carrrnuttt's Avatar
carrrnuttt +50carrrnuttt +50
The AZsolo2 road racing organization here in AZ has a guy with a STOCK (except for sticky tires) 91 SE-R in its Stock class, that beats most of the cars on the track, regardless of class. My friend with a turbo RX-7 has never beat him, and he said that he has seen this car whup-up on cars that are supposedly out of its league, like Corvettes and caged racers.
They hate the guy. Makes everybody look bad.
But then again, the dude has been road-racing for 30+ years.
BTW, here's one of my favorite links:
http://www.speedventures.net/event_r...esults=OA&s=lt
Pay attention to car #12, that car's HP, and the cars that are BELOW it in the standings...
2002_Nissan_Maxima_6-speed
carrrnuttt is offline   Reply With Quote
Bookmarks
Google
Web AF
