Fat front bar for Accord??dwmilton 02-03-2004, 11:51 PM Just an FYI for you Accord owners. I've been trying to beef up my 1995 Oddy van and found (contrary to info I was told) it DOES NOT have an Accord front anti-roll bar. The Accords (94-97 gen) used either 23 or 25 mm front bars; my Oddy has a 30 mm OEM. So...you may wanna see if an Oddy bar will bolt up to your Accord, and just install some poly endlink bushings. Also, if you find the bar will work and get one from a junked Oddy, grab the bar-frame bushings too (if they look to be in good shape)...the OEM bushings are black polyurethane! Mine were in great shape still, no squishing/deflection, and felt stiff, but the rubber endlink bushings were TOAST (I guess they took all the abuse), so they were replaced with black poly bushings. Hope this maybe helps someone out there! Darrell Automotive Network, Inc., Copyright ©2012
