where does it go?
jbmays
12-29-2001, 03:21 PM
I installed a cone air filter with an adapter plate on my p10 today. One question: I removed the airbox, and it has this little sensor that screws into the side of the box. What is it for, and where does it need to go? It seems to run the same with it connected or disconnected, so I am confused. I thought it might be intake air temp or something, but nothing is different when I unplug the harness, so what do I do? I figured it'd be best to put it in front of the filter in the center, but somebody else has to have dealt with this, so please hook me up with the info!!!!!!
Thanks,
Swonder67
12-29-2001, 03:53 PM
Do you have a closed top cone filter? If yeah, you can drill a hole and out the sensor in the top, otherwise, I think you can just kinda strap it near the filter.
NismoPC
12-29-2001, 09:25 PM
Go here to see what I did with mine. Same idea that Swonder67 had stated.
http://nismopc.tripod.com/filter.htm
jbmays
12-29-2001, 11:12 PM
I appreciate the help, unfortunately my filter is one of those that has the doughnut type metal piece with more filter media in the center, so there's nothing to mount it to. I guess I'll have to tape the wire so the sensor hangs in front of the filter.
Thanks for the help:)
P10G20_kenny
01-14-2002, 01:15 AM
about how much does one of those filter setups cost, and how much does it help?
jbmays
01-14-2002, 06:52 PM
Well, it goes for about $45. It's a metal plate and the filter, which is a k&n reusable type. As for hp gains, it feels like maybe there's a little difference, but that may just be me rationalizing buying the thing! It sounds cool at WOT, though. Worth the money to me, and no driveability problems so far...
Jeremy
NA Racer
01-18-2002, 05:01 AM
I have replaced the standard filter on my P10 with a Pipercross foam cone filter and it has made huge gains. Im talking about 10% hp improvement. I have had cam work though which may have caused this.
Also I never had that sensor wire you talk of.
jbmays
01-18-2002, 08:42 PM
It's probably one of those USA only emissions things, so I wouldn't be concerned about not having it. Mine doesn't seem to make much difference, since it works fine with the wire dangling in front of the filter.
NA Racer
01-18-2002, 08:57 PM
Those emmision things must piss you guys off sooo much. We don't have any emmision standards at all. No cat!!!
jbmays
01-18-2002, 11:24 PM
Which makes your car faster than mine. Grrrrr.:flipa:
NA Racer
01-19-2002, 01:42 AM
What was that......?
My...
My ..car...
My car is slow!
I know but cheer up you have more access to things that make it go quicker.
Of course we all know it will never be quite as fast a NZ Primera, but then what is?
:D
TeamNissan
01-19-2002, 10:42 AM
Hello Kenny,
It made my engine more willing to take rpm over 5000 and it made my car go longer on a liter gas! So I don't complain! :)
cliffud
01-19-2002, 01:57 PM
ok- i'm glad this issue has come up-
i have had one of those cone air filters (the design i had was the one with the metal donut on top and more filter media in the middle in the shape of a cone) and this is what i've found...
say i'm idle.... and about to make a left turn at an intersection (i'm listing this scenario because it's where this cone air filter can be THE MOST DANGEROUS THING YOU CAN PUT ON YOUR CAR!!!!!... ) so sitting at the light with the filter in- i press on the gas to get the car moving- however- the car doesn't go for a little bit and then it catches on and finally runs...
i tried the same thing WITHOUT the filter to make sure i didn't screw up anything when i installed it and there was NO HESITATION... (this is on an auto transmission, however- the only difference in testing was the factory filter vs the cone filter (same type of weather -air temp, no rain, etc...) )
my theory is that when u drop in your air filter, you are now sucking in more air, which is what it's supposed to do, but this air is not the air that the engine needs... the engine needs cool air, not hot air that has been heated up by hanging around the engine while you've been sitting there at idle. soooooooooooooooo- when u step on the gas in the beginning- the filter sucks up the hot air (for those of you who weren't chemistry majors in college- the hotter the air - the more diluted the oxygen molecules per cubic foot of air, hence- when you get a COLD AIR INTAKE- you are relying on the fact that cooler air will have more concentrated oxygen molecules per cubic foot).
ANYONE HAVE SIMILAR EXPERIENCES WITH YOUR CONE AIR INTAKE??
i've since removed mine and put back my stock filter - and on the last tank of gas with a lot of highway miles - i reached 300 miles on one tank. well- i also removed the bpt valve from the engine bay because i wanted to clean it (and i still have no idea how to clean it) and i haven't put it back on yet.
ok...
enough jibber jabber on my part-
your turn.
c.
NA Racer
01-20-2002, 02:04 AM
I did that stereo thing, turned it way up! I had driveshaft issues for several hundred Kms (or miles) Only works untill the CD stops!!! DOH
jbmays
01-20-2002, 02:42 AM
You may be right about the hesitation thing, but it's been really cold since I installed mine, so I haven't had that problem. Thanks for the tip, and I'll be interested to see if mine does that when the outside temp warms back up above freezing...
Thanks,
TeamNissan
01-21-2002, 04:43 AM
ok...
your turn.
c.
The air has to be REEEEEALLY hot to stall your engine like that! Especially when it is Non turbo. So for people living in "normal" weather conditions, then it doesn't seem to be a problem.
I had my car in France for 4 weeks last summer with temperatures over 30 degrees and I was in all altitudes from 0 to 5000 m and I had NO problems at all.
So I cannot share your opinion, but not saying that it isn't true what you are saying. :)
cliffud
01-21-2002, 05:29 AM
yeah- in arizona the summers can get up to about 110 degrees F
however- during my tests- the weather was a very agreeable 75-80 degrees... not an extreme temperature.
and... i have a p10... i don't know if the design differences under the hood between a p10 and a p11 are significant enough to warrant such a difference. i do know however that the air right by the engine is a helluva lot hotter than the air just behind the signal lamp (location of air intake on a stock p10) and if you don't believe me
c.:smoker: put your face right around where the filter sits...
i'm pretty sure the stagnant hot air causes at least SOME hesitation due to the diluted oxygen molecules because the same reasoning is used when justifying the installation of a cold air intake (to find dense oxygen molecules).
any ideas?
c.
jbmays
01-21-2002, 10:24 PM
My friend has a subaru 2.5rs, and has a cone filter like what we're discussing. He had hesitation initially with his, but it was only til his computer recalibrated to compensate for the extra air mixing with fuel. He hasn't had any problems with heat, and the filter location is similar, except on the opposite side of the engine.
cliffud
01-22-2002, 03:29 AM
Originally posted by jbmays
... He had hesitation initially with his, but it was only til his computer recalibrated to compensate for the extra air mixing with fuel...
just out of curiosity - how long did it take for the computer to adjust?
c.
TeamNissan
01-22-2002, 04:47 AM
any ideas?
c.
Hey C!
Here in Denmark it would be a total waste of time and money to buy it, but K&N have made something called a "Powerblanket" There isn't much power in the blanket*LOL* but it is a blanket you put under you kone filter to prevent heat from comming up from the engine, and then you just have a cool pipe from the front up to the blanket! :)
Sorry for the poor quality
http://files.automotiveforums.com/uploads/821271Powerblanket.jpg
http://files.automotiveforums.com/uploads/571520Coolpipe.jpg
