98 flashing control lights
tkearney
02-02-2004, 05:17 PM
Last night my son need to jump start the van. Thids morning my wife found 4 of the six air cond/heating control panel lights flashing. These are teh small light that come on when the button is activated. After about 10 mins the lights stop lashing and wnet out?? also the two that are no flashing do not come on when pressed??? everything seems ok other than that???
daveyhouse
02-03-2004, 12:09 AM
I copied this post for you. You have to recalibrate your system. This post is from another 98 caravan
All you need to do is start your van. (if you are unsure what knob or lever is which I am looking in the manual for proper terms) Then slide your temp lever all the way to the right (full cold). Then turn the Mode Control to 'panel' (the one that sends air to your face only). Then turn the 'blower switch' to all the way to full. Now go to the leftmost three buttons. Press the top one (rear wiper on constant) and the bottom one (rear wiper washer fluid). Hold these two for a few seconds. Once the lights come on solid then begin to flash you can let go. The AC will now calibrate. You will feel the air blow out of all the different zones at different intervals and see lights come on and go off. Then after a minute or two the top bottn you pressed will be slowly flashing. This means it has been completed (I actually let it run for 5 more minutes just in case something else started blinking). Press the last flashing button and you are done. I then turned off the van and started it back up and now I don't have those infernal blinking lights for the first fifteen minutes of my drives. Thank you to whoever it was who posted the initial answer to this problem.
