OBD II Scan Codes P1311 & P1312
jvobrien
01-31-2004, 08:28 PM
Both P1311 and P1312 are manufacture specific codes. Does anyone know what the specific fault is for these codes. Thanks
2eyefishclaw
01-31-2004, 10:07 PM
P1311 = Ion Sensing Module SEC 1 line circuit fault
P1312 = Ion Sensing Module SEC 2 line circuit fault
rodeo02
02-01-2004, 12:48 PM
Sounds like either your GM/delphi :banghead: ion sensing module pooped out (it's the finned aluminum box under the plastic cover on the intake), or you are using spark plugs other than denso on your 2000+ 3.2L ONLY use the identical brand/type of spark plug that your 2000+ came with from the factory.
G/luck
Joel
2eyefishclaw
02-01-2004, 12:59 PM
some of them came with Champion plugs if so dont replace them with champions use Nippendenso if that dont work you can bet that the Ion module has taken a dump
