whats a code 23 or is it 10 and 13 code??xplhavoc 01-31-2004, 03:16 PM I had 2 codes before a 10 and 17. fixed the 17 and i thought i fix the 10. When i drove down the street check engine came on flash 23 or is it 10 13. Wire loose??? thanks seadoo920xp@sbcglobal.net CivicSpoon 01-31-2004, 04:07 PM How long was the pause between the 2 long flashes (10's) compared to the pause between the 2nd long flash and the single flashes (1's) at the end? If there was only a short pause between the 1st two then it's a 23 (knock sensor). If there is a slightly longer pause between the first 2 (10's) then it's a 10 and a 13 (intake air temperature sensor and Barometric sensor respectively). And with any of those it could be a bad wire, loose wire, or bad sensor. Is there anything else wrong with it; is the motor dogging-out or idling bad? xplhavoc 01-31-2004, 07:37 PM How long was the pause between the 2 long flashes (10's) compared to the pause between the 2nd long flash and the single flashes (1's) at the end? If there was only a short pause between the 1st two then it's a 23 (knock sensor). If there is a slightly longer pause between the first 2 (10's) then it's a 10 and a 13 (intake air temperature sensor and Barometric sensor respectively). And with any of those it could be a bad wire, loose wire, or bad sensor. Is there anything else wrong with it; is the motor dogging-out or idling bad? Ok thanks well, I fixed code 17 speed sensor and vetec now kicks in hard but when i turn the car on no check engine light, after a little bit check engine light goes on. Blink Blink one two three stop. Blink Blink one two three stop. etc.... Feels like there should be a little bit more power on bottom... Top is good. When it gets to 5500 vetc kicks hard. Bottom kinda lags.. jeff xplhavoc 01-31-2004, 07:39 PM And i have a new 10 sensor and 17 sensor.. $$$$ Automotive Network, Inc., Copyright ©2012
