Help!!
just me
01-30-2004, 10:42 PM
OK, 95 Neon, it was bogging down a bit tonight on acceleration (yes the air filter has been changed recently),then it started to make a buzzing/static sound from the front,sounds like from the passanger side intermitently,then the idle went high while stopped at a light,then it would seem to lose power and stalled out on me. It started right back up though....any ideas??? I use this car for work and I drive for work. Any help would be appriciated!!!
pegasus757
01-30-2004, 11:06 PM
Hard to say too many things it could be . the only clue is static sound.. If you hear a snap snap sound coming from engine check the plug wires for arcing ....car runing in a dark area you will see the sparks jump. if so a quick fix is wd- 40 spray wires with engine off. check it again. If plugs are worn out this will cause arcing
NJH_Habitatpro
01-30-2004, 11:10 PM
check your throttle wire it could be loose like the clip make sure that all the wires are in tight you may have to take to a mecanic for this inless you know what im talking about and hwo to do it. the static sound i would check my belt just check to see if worn.
just me
01-30-2004, 11:36 PM
Thanks I will check it out,the idle semmed very high for a few days ladt week and it read a code 51 also. The check engine light went off and it seemed to act fine until tonight,I had chalked it up to the 10 below zero weather we were having,I am looking up a few things in my Haynes manual right now.
Scatch!
01-31-2004, 12:12 AM
Have you looked at your plugs and wires? How about the battery and alternator connections? You can get the last two checked for free at most auto parts stores.
cyber_lord
01-31-2004, 10:40 PM
have you done the self diagnostic to see if any codes came up? just in case whatever it was has a sensor connected to it?
look here > http://www.neons.org/neontsb/diagnost.htm
just me
02-01-2004, 10:57 PM
Yep,it came up code 51.fuel lean.Now I have this buring smell like a belt is buring,it is at the shop now,thanks for all your help guys! Still love my Neon,my first one (95 also)went 267,000 without doing the headgasket and very monor repairs,a starter and an 02 censor,cant beat that :)
