Rear Window Washer
70camaro
01-30-2004, 11:37 AM
The rear window washer on our '99 rav4 L quit working. When I went around back to see if I could find the problem, I discovered the fluid was leaking out of the the bottom of the rear quater, behind the rear wheel. I'm guessing the hose ruptured (it's been REALLY cold lately).
Has anyone else had this problem, or know where the hose is routed and how to get to it, so I don't tear apart something I don't need too???
jm102399
07-20-2005, 04:53 PM
I had this problem, behind the rear passenger seat there is small door there should be some screw or so to remove a panel this is where the hose is disconnected you must move the rear seat also to access the hose you wont do too much removing.
Good Luck
