startercarpunk 01-29-2004, 09:45 PM My friends 95 neon is dead problem is when i turn the ignition to start it absolutely nothing happens. No clicking, cranking, no power to starter checked the battery, fuses, and relay and all are fine any ideas ? cyber_lord 01-30-2004, 07:14 PM Does the stereo and lights come on? If not, check the ground cables. If you have a mulimeter, make sure there is little to no resistance on the cable. Other than that, I don't know unless I know about the other electronics.(if they work or not) carpunk 01-30-2004, 07:27 PM Does the stereo and lights come on? If not, check the ground cables. If you have a mulimeter, make sure there is little to no resistance on the cable. Other than that, I don't know unless I know about the other electronics.(if they work or not) Stereo, lights, heat all work battery is fine even tried to jumo it with my car Automotive Network, Inc., Copyright ©2012
