PLEASE help quick !! '01 Rodeo Check engine light/$400!?!?!BrettnATL 01-29-2004, 11:46 AM PLEASE help, ASAP! I'm leasing a 2001 Rodeo with the 4 cyl...lease is up in a couple of weeks, and warranty just expired a month ago...the check engine light is on and they're telling me it's the Cam Sensor (?) and it'll cost around $400 to fix it!?!?! the dealer claims that isnt covered under powertrain warranty, and basically i'm out of luck since the bumper-to-bumper warranty expired last month. Funny thing is, I had it in 2 weeks ago for the check engine light, and they replaced the fuel pump assembly, and the light came on the very next day. So this problem happened overnight, literally??? I think I"m getting screwed. ANY help or advice, please let me know. I'm turning the vehicle in off of the lease in a week or so and have no clue what to do. amigo-2k 01-29-2004, 01:18 PM disconnect the battery (15 minutes at least) and see if the CEL comes back on. If it stays off for a few days, you do this right before you turn it in. Or maybe you can find out where the sensor is, Pull it out clean it up and re-install it. Or just have the dealer (or other place) just replace it. -Ryan 2eyefishclaw 01-29-2004, 11:19 PM how many miles are on this Rodeo if you are under 60,000 it is covered you have a 5 yr 60,000 mile warranty and your drivetrain warranty is 10 yr 120,000 miles if this was a new lease BrettnATL 01-30-2004, 10:31 AM thanks for the info...actually, my Rodeo only has 36,200 miles on it..it's a 2001 model. I was told it had a 3 yr/36k mile bumper/bumper warranty, and that ended at the end of December, and that this 'cam sensor' isnt part of the powertrain.. maybe they're trying to screw me on my warranty? amigo-2k 01-30-2004, 11:23 AM http://www.isuzu.com/owners_warranty_2000to2002.jsp Nope it is 3yr/50k. They are trying to screw you over. You may want to get in contact with your regional rep to help educate your dealer, and give Corp Isuzu a call too to help out. Also, you should print and fax off the above link and read through your manual in the glove box for more ammo. BrettnATL 01-30-2004, 11:32 AM hey buddy...thanks, I appreciate the info..but the issue is, the car turned 3 yrs old at the beginning of January. I asked them since I had it in for this problem originally only *2-3 weeks* after it hit the 3 year mark if they could go ahead and cover it under warranty, and they said NO. amigo-2k 01-30-2004, 12:28 PM If your lease start on Jan01 then you are correct. Some dealers will do warrenty work under good faith if it is only a couple of wks or miles out of warranty. You could take it to another dealer (if that is an option) and see what they think, or just get it fixed. -Ryan chcklngm 01-30-2004, 06:34 PM Here's what I would suggest you do first. Go to an AutoZone or some similar parts store where they will do a free diagnostic check. They will hook up a monitor to an interface usually located under the dash. That will give you a code and tell you what's the problem. Use the code to look up the Chilton's manual. In my case, I traced the problem back to a fuse using their circuit diagrams. I replaced the fuse in the fuse box and the light went out. Hopefully it'll work for you. Let us know how it goes. Regards, Bk. Automotive Network, Inc., Copyright ©2012
