hydrolicsChavez408 01-29-2004, 01:26 AM would hydrolics affect the car's porformance?handleing? and im guessing its going to add weight to the car so it will slow it down but post enought info as u want. anything is fine and it is for a import car. just helping a friend on this :) sorry if its a repost or the wrong forum to ask, but im just curious about this, and yea im going to do research too but i want some info from everyone please :biggrin: GTR2b 01-29-2004, 01:52 AM "Hydraulics" will ruin a car's handling. Other than the added weight, it will stiffen the suspension to the point of causing the car to bounce on the slightest crack in the road. Basically because the pumps replace the shocks which are designed to eliminate the rebounding of the springs after they are compressed. blindside.AMG 01-29-2004, 02:04 AM "Hydraulics" will ruin a car's handling. Other than the added weight, it will stiffen the suspension to the point of causing the car to bounce on the slightest crack in the road. Basically because the pumps replace the shocks which are designed to eliminate the rebounding of the springs after they are compressed. :1: Hydaulics will make your friends car ride worse than an old Jeep with leaf springs. I would suggest air bags a hundred times over, especially for a Japanese import car if you really need ride height adjustment. Hydraulics are old and basically useless unless you intend to hop your car. broddie50 01-29-2004, 02:28 AM If you'd lived in California over past 25+years hydro's are for fishin for breezies! blindside.AMG 01-29-2004, 02:37 AM fishin for breezies! Um, yeah,whatever the fuck that means? :rolleyes: Toksin 01-29-2004, 02:53 AM I agree. blindside, isn't LA like the friggin hydro capital of the world? Chavez408 01-29-2004, 06:41 PM ok thanks guys! i also been searching and iv found some good info, but keep it up :thumbsup: Porsche 01-30-2004, 12:54 AM hmmm, question: The (for example's sake) Lamborghini Diablo has some special pneumatics to lift the cra a few inches when going over speed bumps or high attack/departure angle driveways, hwo does this system work? Is it just small bags or some sort of super shock? mind you the car still has normal functioning suspension, although I'm told for cars such as the Diablo, don't drink and drive with a coffee. TexasF355F1 01-30-2004, 10:41 AM hmmm, question: The (for example's sake) Lamborghini Diablo has some special pneumatics to lift the cra a few inches when going over speed bumps or high attack/departure angle driveways, hwo does this system work? Is it just small bags or some sort of super shock? mind you the car still has normal functioning suspension, although I'm told for cars such as the Diablo, don't drink and drive with a coffee. I too have wondered this. I think it could be a small air bag specifically used to raise the front end. Or it could be built into the shock. Kind of like an air shock. But I still don't know. js52589 02-14-2004, 05:04 PM im pretty sure the diablo (and cars with similar setups) use helper bags (to assist the coil springs) lots of trucks use this to keep it even when towing something big SaabJohan 02-15-2004, 12:57 PM This depends on what you are going to do with the hydraulics? All high perfrmance cars use some sort of hyraulics system, it can be hydraulic activated clutches, differentials, power steering or even hydraulic actuators instead of conventional dampers. The use of hydraulic actuators instead of conventional dampers was used by Williams in their F1 car in the earliy ninties. This system offers a superior suspension system which also was one of the reasons why it was banned from F1. The system was design so that the car held a specific ride height. The constant ride height gives aerodynamic advantages but the car will also never roll in turns or change the yaw angle during braking or acceleration. It can also take bumps in the road much better since it can lift the wheels. This system is also superior to all commercially availible semi-active system, most using simple hydraulics to adjust suspension stiffness (some also use pneumatics). Chavez408 02-21-2004, 02:59 AM my friend wants cus of his body kit that he is gettin he does not want to break it or scratch when his going up a driveway or while parkin so he wants to raise the car when his going in his driveway...nothin special :) Automotive Network, Inc., Copyright ©2012
