1jz swap
Google
Web AF
KAZAMATANG
01-28-2004, 11:50 PM
i am buying a 1jz clip and it comes with the full engine, turbos, transmision, ecu, wireing harness, driveshaft, lsd rear end, what else am i goona need to do the swap, from the looks of it all i am goona need is exhaust, but i am dumb so want to know from people who have done it before, thanks guys
projectsupramk3
01-29-2004, 12:52 AM
"If you got a front clip everything is bolt in, all you need to do is lengthen the harness, find a 89+ crossmember and mounts, get a LHD 2jz throttle cable, and a high pressure PS hose from the 93-94 MK4."
If you would have checked out the other sections you would have found my post, explaning the very things you would need besides the front half-cut. For the exhaust any shop can easily make up custom just make sure they use mandral bends though, or you can find a buddy to help you weld one up, or you can shell out the cash for a JDM exhaust setup which is going to mean big bucks. Good luck on the swap though, it seems like lots of people are trying it now. :)
Google
Web AF
